Final thoughts on half cage...
Gotta make a decision on a half cage for the 10 RS. Please please give me your opinions on the best fit for me.
1. Must attach to shock towers.
2. Must allow room for my seat to go back...I'm 6'2".
3. Needs to be as light as possible. (of course)
Thanks guys...always the BEST info here for the P cars.
really light cages are carbon and aluminum cages but then again who dares?
so lightest+steel and meeting you are two criteria is the 996 gt3 clubsport factory rear cage.
was made by IVM AUTOMOTIVE GMBH for porsche and the rear weights 3kg less than any other cage porsche made after.
John
John
- Safety Devices cage, imported by Stable Energies in NJ
- plates welded in and then it bolts in
- big advantage of this cage is that the harness bar can be easily removed as it is bolted to the hoop
- the diagonal can also be removed if you choose that option
- plenty of room for seat to go all the way back
- there are probably lighter cages out there
John
John
Does it bolt to the shock towers? I went that route last time and don't remember if it did. But my stock seats presented a problem going back. Better with these seats?
Clarifying,
I mean the factory bar that bolts to the rear shock towers and in some cases with the earlier MK1 RS's bolted directy to the floor plates just behind the front seats. There is room behind for seat movement. This is not the Porsche Tech bar.
Hope this helps.
Hope this helps.
Clarifying,
Hope this helps.
Hope this helps.
part number is 996.580.982.01
for the 997 cage which is heavier you can try any dealer.
in both cases you need to weld 3mm thick plates with at least 120qcm of surface area so that it will be installed properly.
The odd used clubsport bar becomes available on rennlist for cheap, but alas i havent seen any in awhile.
i can put my GT2 seats all the way back with clubsport bar. Im 6.0ft and still have lots of room to go back if needed.
you will need to weld the factory plates to the floor and then bolt in the roll bar.
The new cars no longer offer factory plates like you previous RS.
I have seen clean jobs of this and have posted pictures on rennlist:
https://rennlist.com/forums/showthre...ferrerid=62449
