997 GT2/GT3 Forum 2005-2012
Why doesn't Porsche want to build a Cayman GT3?
Old 05-31-2010, 03:12 PM
russo
russo's Avatar
Cayman sales, although the Cayman costs less, have never been at the level of the 911. Why would Porsche take a big chance on the Cayman only to cannibalise the 911? What next? Eliminate the 911? when it continues to outsell all other models? Next thing you know Porsche will be racing the Cayman instead of the GT3?
Old 05-31-2010, 03:28 PM
MJSpeed
The Rebel
MJSpeed's Avatar
Originally Posted by C.J. Ichiban
...it's doable to get 380hp or so VERY RELIABLY from a cayman. start tearing out the foam and carpeting and replace with something light- shave a few pounds here and there and you've got a 80-100k track day toy.
or you could just get a used 997gt3 mk1 and save yourself 2 months of labor and development
+1 BINGO...the only way it makes sense, to me at least, exclusive of any financial logic, is if you already own a Cayman and want to maximize the platform.
Otherwise I'm buying a pre-owned GT3/RS.
Old 05-31-2010, 03:29 PM
triode
triode's Avatar
The oldest reason in the world: $$$. Why cannibalize more lucrative 997 sales?
Old 05-31-2010, 03:43 PM
_rocket
_rocket's Avatar
Originally Posted by GrantG
The 914-6 had the least powerful 911 motor available (110hp from the 1969 911T 2.0)
Why not detune the GT3 motor then? I'd rather have a 300hp GT1 block engine than a 320hp 9A1 engine.
Old 05-31-2010, 03:47 PM
_rocket
_rocket's Avatar
if you really want a hot motor in the cayman- just get the 3.8 x51 installed. that should be plenty.
I have driven a 9A1 3.8 Carrera S but it lacked soul and character as it was too smooth and too quiet - it sounded like my Dad's Lexus.
uncle buck
uncle buck's Avatar
You and I both would, but I'll wager the majority of 987 buyers would not care or more candidly, do not know the difference. The 9A1 motors are pretty good and down the road may prove to be every bit as robust as the GT1 based motors with far less expense.
Old 05-31-2010, 03:49 PM
_rocket
_rocket's Avatar
Originally Posted by Carrera GT
So your dream car is also qualified by the condition that it's factory built?
Porsche finally answered that question with the Boxster Spider.
1. Yes
2. The Boxster Spyder is 9A1 based, not GT1 block.
Old 05-31-2010, 03:54 PM
_rocket
_rocket's Avatar
Originally Posted by Nizer
Easy enough to do yourself if it's your dream car. Find a wrecked GT3 and a used Cayman then breed them. It'd be one fast mutt.
The GT3 gearbox can't be used because its crown wheel cannot be flipped to other side. A new gearbox would be required - easy for PAG to do.
Old 05-31-2010, 03:56 PM
_rocket
_rocket's Avatar
Originally Posted by aussie jimmy
there is a boxter in sydney with a gt1 from a mk1. wasn't an easy job, but can be done.
Yes I read that article, it was interesting.
Old 05-31-2010, 04:16 PM
DJN
DJN's Avatar
Porsche has been building and racing sports cars for a fairly long time, and they have been doing a very good job at it too. The real reason we don't see a Cayman GT3 is because the 911 platform makes for a better racecar. The 911 takes addtitional skill to drive, however, this does not mean it is slower around a given racetrack (more on this in a moment). Also, it makes for an extremely exciting race series. Why has the Porsche 911 been the focus of many single model race series worldwide for so long (....I'm asking you)?
Anyway, two summers ago I had the opportunity to drive a well sorted 997 S and a well sorted Cayman S with an X51 upgrade back to back. They had equivalent straightline speed with their 3.8 L Carrera flat sixes (confirmed from the Traqmate GPS data), brakes, and nicely set up suspensions with aftermarket nips and tucks, also both were on R-compound tires.
The tail-heavy 997 (911) gained its lap time advantage in being able to get the power down on corner exit. The improved grip is achieved by the combination of additional rear weight, rear-wheel drive, and therefore useful rearward weight transfer. Also, the 997 S also had a larger rear contact patch with 305-width tires (Cayman 265 OEM, and 275 upsize in this case).
Porsche AG has likely know this all along.....long live the 911, slow in, fast out!!!
Cheers!
Doug N.
Old 05-31-2010, 05:23 PM
RAPID
RAPID's Avatar
Not a standard Cayman S (it does not have a 3.8l)...
Old 05-31-2010, 05:59 PM
911SLOW
Admin
911SLOW's Avatar
Red face
Cheers!
Doug N.
If Porsche could somehow brainwash the world to forget the 911 and maintain its sales they would destroy the rear engined cars in a blink of an eye and replace them with a "modern" mid engine layout..
Old 05-31-2010, 07:26 PM
Tacet-Conundrum
Tacet-Conundrum's Avatar
Why do all the magazine comparos, with journalist behind the wheel, always eek out lap times that are typically within one second of one another? That is 911CS and CaymanS! Note that the cars are never driven by top tier racers like Walter or Hurley.
Old 05-31-2010, 08:13 PM
DJN
DJN's Avatar
911 Slow - fair enough, but you know where I'm coming from.
TC - I suggest you read the article more clearly, each of the cars tested were fairly well set up for track day adventures and modded to within 35 hp of each other, so I wasn't surprised by the lap results - furthermore I was not driving for the hot lap testing on this occasion, a former Australian Porsche Cup did the deed for me because I was too familar with one of the subjects.
You should not stand on you without all of the facts !
Also, while I do write for some magazines, I'm not a "real" Journalist, I'm actually a "mad" scientist who plays with cars and teaches performance driving to anyone who is keen to learn - thanks! Doug N.
Old 05-31-2010, 09:01 PM
MM3.9GT3
MM3.9GT3's Avatar
either way- it's doable to get 380hp or so VERY RELIABLY from a cayman. start tearing out the foam and carpeting and replace with something light- shave a few pounds here and there and you've got a 80-100k track day toy.
The problem is that I already have a 997 GT3! Don't tempt me with the X51 conversion from RAC Performance. I already spend too much money there!
Quick Reply: Why doesn't Porsche want to build a Cayman GT3?
