Any interest in titanium exhaust tips for the GT3?
#46
I got a set here I'm going to be using as a paper-weight although once the AC comes on they might actually fall off the table they're so light
Thanks Larry and I just heard James driving around back with the RS (giving someone a demo) with the bypass so I think you'll dig that sound too
#47
+1 on the carbon ...
cant wait to put the bypass on ... thats my Jul 4th project ...
I could not believe how light they were and how heavy the factory tips are! ... amazing!
#48
Thread revival - do you have any left? Contemplating putting those on my RS.
A part from looks, does it change slightly the noise/sound pitch of the car?
Also i heard that because they were of larfer diameter there could be some problems with the standard exhaust...rumors or true?
Cheers
Cheers
#49
Cheers
Cheers
I have experienced NO problems with the bypass or tips ... so any rumors were exactly that ... totally imagined...
I can post pics if you like ...
do you have the shark bypass also?
#50
no i don't - i run stock exhaust because here in the UK most track days are quite restrictive on noise level: static 101dB at 6000rpm (which is hard to reach...more like reving at 5,000) and 87.5dB fly-by !
Thank god hitting Silverstone next month where i don't have to worry about anything
I'm only looking for something which would me just a tiny bit louder and higher pitch...hence thought mayeb by changing tips i could achieve that - it did the job on the old air cooled 993s.
#51
#52
Changing the stock tips out for the Sharkwerks larger diameter tips will increase the sound, albeit very slightly. On both my 07 and 10 GT3's I replaced the tips on the factory center muffler before I did a bypass and I can confirm it increases the sound just a bit...
Cheers
Cheers
http://www.sharkwerks.com/products.php?pid=173
