Oil change procedure
Can anyone provide me with the oil change procedure for a dry sump; specifically the .2 GT3?
And, what is a safe amount of oil as to avoid any overfill? I know the sump holds about 10 quarts, but don't want to oevrfill at all.
TIA.
TIA.
GT3 player par excellence
OIL CHANGE
Oil should be changed when the engine has reached normal operating temperature. CAUTION - oil will be hot, take adequate precautions to avoid being burned.
1. Use ramps or jack up the vehicle at the points provided.
2. Remove the oil drain screw and collect the engine oil in a disposal container (at least 9 quarts). Always dispose of the waste oil in accordance with local legal requirements.
3. Wait about 20 minutes for all the old oil to drain. Then clean the oil drain screw and screw it back in with a new aluminium sealing ring. Tightening torque is 37 ft-lb.
4. Remove the oil filter housing with the oil filter wrench and unscrew the housing.
5. Remove oil filter housing vertically downward. Drain remaining oil into a disposal container.
6. Remove the filter element. Remove the filter downwards, drain and dispose of it in accordance with local legal requirements.
7. Clean the oil filter housing thoroughly inside and outside and replace the O-ring . The O-ring should not be levered off or on with a sharp object (e.g. screwdriver). A sharp object will damage the O-ring.
8. Install the new filter element.
9. Lightly apply oil to the O-ring and housing threads. Install oil filter housing and tighten to 19 ft-lb.
10. Fill with engine oil. The oil change quantity is approx. 8.75 liters (8.25 liters for MY02 and newer 3.6 liter engines) after a draining time of approx. 20 minutes.
these are instruction for 996 and 997.1 gt3/rs. it is the same for .2 as well, but i am not sure of oil capacity. i usually dump 9 bottles in there, never once overfilled.
Thanks!
So, the dry sump is nothing really different from any other responsible oil change? I thought I had read here somewhere about there being more than one drain plug and other specifics pertaining to dry sumps. A previous search did not yield anything specific.
I'm going to have my dealer perform this one then plan to do the rest myself. You never know how meticulous the tech is; or isn't.
GT3 Oil Drains
There are two drain plugs on the GT3 engine ~ you may want to check Loren's procedure on RennTech
That is my understanding 911dev as it is at the lowest point (as indicated by the earlier workshop diagrams in Box01s's post) and the other is the one at the bottom of the tank as was correctly indicated...
SORRY, IGNORE MY DIRECTION. in a hurry, i posted non GT cars.
there are two plugs. the other post showed correct pix
also, when you take the plug off the oil tank near RR wheel, put a wrench on the neck above the plug, you dont want to break the neck off the oil tank.
furtheremore the oil filter on on top side of motor. so you dont pull it down as my WRONG post said. you pull it up!
Where did you get the jack stands in the photo of the GT3?
Do they fit into the cicular jack points on the car?
Thanks, Rich
Thanks again for the help from everyone.
First oil change at about 1,100-1,200 miles, to be done by my dealer Tues. I will be with the tech when he does it. I'll do the next ones on my own if I can find the right ramps or jack and stands. At least now I know what to look for when my car is worked on. He's new to the dealship and I want to be ceratin the filter housing is wiped out and that the oil is completely drained from the tank. Yeah, I'm a bit meticulous.
It's all good. I figured you thought it was a non GT car.
get to both drain plugs without raising the car.
Thanks^
How many quarts should I pour in before checking the level for the first time, 9? The manual reads that iit may take 9.5 but am I safe with 9 first, then check the level before adding? I don't want to over-fill.
