dB Rating of Stock 997.2 RS exhaust
Still plays with cars.
Guys, my home track is sound restricted, 92 dB measured at 50 feet using the A scale, fast response. They use a professional meter which is calibrated twice a day. My 2010 RS clocked the same level as my 2007 RS, 86 dB. I was worried because of the posts I saw here. There were two of us on the track and neither one exceeded 86 dB.
Standing track side, the new RS sounds no louder than the GT3 or the Mk 1 RS. Both our cars were running in "sport" mode i.e. flaps open. Measurements are taken at various locations, all chosen because cars are running high rpm full throttle. We do not see the people taking the measurement so we can't lift and sneak past.
Hope this helps.
best,
Hope this helps.
best,
Hope this helps.
best,
Hope this helps.
best,
In their genius, Laguna measures up-hill where the new 911's are at the top of 3rd gear, at track out. If there's low cloud, it increases the dB. If there's two 911's together they resonate and it increases the dB. The intake is contributing, so stuffing foam in and around the intake helps suppress dB.
If you hear a screaming RX7 go by, you'd swear it's going to crack the sky. Then the driver just "shifts and lifts" then repeats the same subterfuge at the second "roaming" check station before T7 then they scream all the way up the front straight. Crazy. And when a 911 goes up the main straight, it's nice, but it's practically silent.
Someone should find out where they live, board up their windows, nail their doors shut and cut phonelines... job done...
One trick you may consider is to add extentions to the end of the exhaust which point to the ground. This works well on my Cup when we have Sooks complaining at Sandown in Melbourne.
They also have sound metres at various points on the track
All because of local owners who bought houses next to a track that has been there for 50+ years
Although this is not my Car, I have a similar system.
One thing to keep in mind is to ensure that you have a good clamping device to fix the end pieces on securely.
