Anyone try the Kumho V710 in 18"?
I do 31 hot all around on kuhmos- works great for me. Cold temps I start with 25 and adjust from there. I use 245/40(square) and 305(square). Your 1st post is round version in 245/35 and 315. I do drive to/fro track on them provided it's not a rainy day. Drove to thill last weekend. Great tire- when it does slip it's catchable not the snap and spin kinda thing wo alert. No experience with hoo hoos yet though I have a set laying around but like the fact I can flip them and no deterioration in performance. I've done kuhmos and hoo hoos on my gti and I like the kuhmos better. For some reason hoo hoos are abit vague at the limit feedbackwise though it grips well- kuhmos I get more feedback at the limit. Regards. Mike
According to the tirerack website, the front 245/40R18 is squared and the rear 315/35R18 is rounded. Apparently, the round tires are really wide for their size. I may give NJ's sizes a try which lowers the CG and gears the car up a bit or I may stick to stock-diameter sizes and risk some rub in the rear.
My car is used mostly for short weekend drives and track use, so I think the V710's can be left on. I'll have to be careful about punctures and ANY standing water. My RA1's are not even broken in yet, so it will be June before I need a new set of tires. I'll report back when I get the Kumhos on.
It was for autox, but I think it was 32f/34r. I really should write these things down. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I have about 22HC on my R6 so I need to order some new tires. Last time I drove the R6 was last Sept. I'll give them a shot at my local track on May 12 and see how the lap times compare. Should be interesting.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
315/35 messed up 996 GT3 ABS for a friend of mine. Too tall.
GT3 player par excellence
mike and i had discussion on this.
245/35
245/40
305/35
315/35
square vs round.
why two profile shapes....
ugh... i give up. just run R6, easy.
245/35
245/40
305/35
315/35
square vs round.
![](http://i60.photobucket.com/albums/h7/00miata/Forumn%20links/rlst2.jpg)
At least from experience running both round and square though round has a wider contact patch- the square has much better turn in then round just FYI but same grip levels- u can't beat that. Mike
Yes! More of a reason to keep square 245/40/18 front. I like to run 245/40 and 315/35 because I am in contract with the track to plow their field couple times a year. Higher profile tires will minimize damage to rims during my agricultural excursion
The stock 19" tires are:
Front: 235/35R19 @ 25.5" diameter
Rear: 305/30R19 @ 26.3" diameter
The comparable 18" Kumhos with the same diameter:
Front: 245/40R18 @ 25.7" diameter
Rear: 315/35R18 @ 26.4" diameter
Difference:
Front: 0.2" diameter
Rear: 0.1" diameter
I'm doing several events now that have 6-7, 30-minute sessions in a day. At this rate with R6 or V710 I'd go broke in no time.
I might need to put down the crack pipe and go back to NT-01.
Mike, order extra V710 and I'll test them for you to see how they work up north.
