FS: Champion Motorsport RG5 wheels, TPM & MPSC's
Set of Champion Motorsports RG5s:
9x19" ET53 (19.97lbs - rim only) 12x19" ET63 (22.1lbs - rim only) (enables the removal of the factory 5mm spacer)
- 4x TPM sensors
- 235 & 305 MPSC's
2500mi approx.
The wheels are cosmetically perfect/new
$3000 rims only
$3600 rims+MPSC
$4000 rims+tpm+MPSC
buyer pays S&H.
- 4x TPM sensors
- 235 & 305 MPSC's
2500mi approx.
$3000 rims only
$3600 rims+MPSC
$4000 rims+tpm+MPSC
buyer pays S&H.
bump - decided to keep tyres and TPM (although still open to offers), selling rims for $2800... + s&h get them while they are HOT!
bump
the rear offsets on the RS vs the GT3 are 51mm vs 68mm, but apparently both cars are fitted with a 5mm spacer from the factory so the actual offsets (with spacer removed) is 5mm less.
The RG5 for the GT3 comes with a 63mm offset, thus obviating the removal of the factory 5mm spacer
entirely.
However in order to fit the narrow body (GT3) wheels to the rear of a wide body RS would require the
use of a spacer in the 15-18mm range which is likely to add a couple of unwanted pounds to the axle.
entirely.
SOLD!
