tire change question
If the cause of the puncture is near the center of the tire then repair should be safe for road use. If nearer the edge then better to replace rear tires.
Do not change just one tire, after 9000km the tread will be fairly worn so the rolling diameter of the rear wheels will be reduced; causing problems if just the one tire is changed.
