MKI VS MKII pads and rotors
#31
The rear stock pads are not all 4 the same, note how the stock rear pads are much smaller.
I did not see them come out, so I wonder what the leading edge is, but assume the slighly slanted part that is cut out?
The stock pads are Pagid R90, I replaced them with pagid R29.
The stock front pads have these 2 pins attached, the R29's do not. What is the function of these pins?
#32
#35
![](http://img682.imageshack.us/img682/4729/pict7258.jpg)
#36
Pagid RS 29 8004 Cup rotor specific pads.
Are we talking about the aluminum cylinder looking things?! I am guessing that they are there to provide some sort of dampening effect.. ?!
#38
#40
The front calipers are also different on the steel brake cars. They now have the same calipers as the MKI and MKII PCCB fronts. Hence why pads are a different size from the MKI.
#41
Yup, I found out that I have the wrong ones...
They fit, but the "hang over" the inside of the rotor, no problem for street driving, but not good for tracking, so I will swap out next week.
#42
Here are pictures of the right 380 mm front one-piece steel rotors from the 997.2 GT3/RS (the others are still in the boxes). They are not installed yet but every measurement indicates they should be a direct bolt in replacement for the 997.1 PCCB front and rear. I have not weighed them either but picking them up gives me a "guesstimate" the 380 mm fronts are in the 20-23# range.
Front 380 mm rotor
![](http://i42.photobucket.com/albums/e324/mkozink/2007%20GT3%20RS/PCCB%20Steel%20brake%20replacements/P1010359.jpg)
In-board side
![](http://i42.photobucket.com/albums/e324/mkozink/2007%20GT3%20RS/PCCB%20Steel%20brake%20replacements/P1010358.jpg)
FWIW- I will have weights and complete part numbers later this week.
Front 380 mm rotor
In-board side
#44
Front 380 mm rotor
In-board side
Front 380 mm rotor
In-board side
with a reusable hat ...
I think you have cup rotors there ...
take a look at the picture mikymu posted ...
#45
Now I am confused. The picture you reference is from mikymu's 11-20-2009 "PCCB to GT3 Cup Steel Rotor- Bitter Sweet Conversion" thread. Correct me if I am wrong but the 2-piece in mikymu's photo is the Cup Hat/Rotor.
https://rennlist.com/forums/7084498-post3.html
Obviously the 1 piece 380 mm rotor (actually it does have an aluminum hat and steel friction ring, but the aluminum hat is not reusable) in my picture is quite different and identical to the steel rotors I saw on a 2010 997.2 GT3 at Mid Ohio on May 1 & 2.
I hope mikymu can verify that his picture is of the 2-piece Cup steel rotor.
