AIM data acquisition system install [pics]
Got the car back from the shop, feels great to be behind the wheel of this awesome machine again. Haven't had the chance to test out the new Guard LSD stack or the Endless brake fluid, but the car feels so so so good to drive.
I'm really apprehensive of mods and usually keep things pretty close to stock, making concessions only when the stock part is not meeting the functional needs for my specific requirement. I took the car into www.euautowerks.com for the AIM install and am incredibly impressed with what they came up with.
The design brief was:
1. Install the EVO4 near the vehicle's centre of gravity
2. Dash should be removable in less than 30 seconds with no tell-tale signs it was there; dash should not block real dash
3. GPS antena should be part of the interior and should not require placement during track days
4. DAS needs to be switchable so that if I don't bring a laptop to the event, the data does not get overwritten with my drive home
5. USB cable needs to somehow be accessible but also hidden
When I originally met with Courtney, I said I wanted to install the EVO4 head unit under the rear panel near the ECU so I could remove/re-install the carpet to get to it at track events. I'd then run the wires up to the dash and to the USB connector. Courtney didn't feel this would be the best approach and to let him come up with some alternatives.
Him and Lawrence installed the EVO4 on the panel near the ECU and ran the wiring up through the centre console for the USB connector and installed a switch so I can turn the unit off and on, without removing any rear panels. For the dash, they came up with an ingenious use of the cup holder and ran the cable along the centre console and transmission tunnel.
It turned out amazing! I love the way it looks and how easy it is to put away when using the car on the street. The dash isn't very heavy so the cup holder should be fine.
I datalogged my drive home (you can see the google earth view of my drive home below!) and these are the channels available:
Vertical g's
Lateral g's
Longitudinal g's
RPM
Throttle Position Sensor
Individual wheels speeds (imagine the fun I can have here with Math channels!)
Engine coolant temp
Engine oil temp
Engine oil pressure
Steering angle
Steering speed
Brake switch
Gear selected
Fuel level in litres
Battery Voltage
GPS lateral g's
GPS heading
GPS gyro
Thank you to Courtney at EU Autowerks (www.euautowerks.com) and to Joe Cooley (www.circuitmotorsports.com) for their help. Here are the install pics. Look at what an awesome job they did!
Please let us know how everything works at the track, screen position and readability looks good!!. Hope the software delvers good and easy to use information.
will you have a camera installed, what about a HD camera?
Keep us posted!!
Rennlist Small
Business Sponsor
