Rs Gear Ratios
Rs Gear Ratios
Does anyone have the actual gear ratios for the 2010 RS?? I know they are shorter than the GT3 but wanted specifics. I managed to find the CUP Car ratios below.
# Gear ratios:
Ring & pinion gear 8/32 i = 4,000
1st gear 12/38 i = 3.167
2nd gear 15/32 i = 2.133
3rd gear 18/31 i = 1.722
4th gear 23/31 i = 1.348
5th gear 26/29 i = 1.115
6th gear 29/27 i = 0.931
# Limited slip differential 37 % / 52 %
thanks in advane,
# Gear ratios:
thanks in advane,
GT3 player par excellence
3.82
2.26
1.64
1.29
1.06
.92
reverse: 2.86
final drive: 3.44
2.26
1.64
1.29
1.06
.92
reverse: 2.86
final drive: 3.44
Mooty those ratios are for the '10 GT3
Here are the ratios for the '10 GT3RS (Bold= Different)
3.82
2.26
1.64
1.29
1.06
0.88
reverse: 2.86
final drive: 3.89
3.82
2.26
1.64
1.29
1.06
0.88
reverse: 2.86
final drive: 3.89
^ thanx for correction.
i should know better that after pupil dilation...
