Porsche Lagune
#31
GT3 player par excellence
regear the whole box, that's it ;-)
#32
I meant on the straight going into 5. Currently I'm just hitting the revlimiter in 3rd before braking for turn 5. With higher corner exit speed out of turn 4, I'll need to use 4th gear before braking/downshifting to 3rd for turn 5.
#33
no matter how fast you exit T4, as soon as you up shift to 4th, you need to shift right back down to 3rd for T5. with R and P, it's slightly better. you will be in 4th earlier but you have to be way fast to make T5 in 4th and big *****. if you downsfhit to 3rd, the car would feel "stuck" in T5 with 4.0 RP.
#34
i'm a much better instructor than mooty, so you should fly me to Oz. i'll send him a postcard. ok, i'm kidding, but i will visit you.
mobonic - don't tell me you didn't get my mufflers on the car ??
#35
If I had to do it all over again I change the gears but at that time did not have $$$ to do it. R/P definitely gives 3rd gear more usable trq but I always worry bout downshift from 5 to 4 at t1 at thill. Mike
#36
997 S's do NOT have LSD stock or as an option... 996 had the option and 997.2 have the option but Porsche took it off the table with the 997.1... which is the car Gomez and I have.,
LSD will be going in when the clutch needs to be replaced along with a LWFW...
#37
Brendan.. mufflers made it but I had the do some magruber techniques to get them on without the correct braket... but I passed sound all weekend with no problems thank to you... I owe you buddy!
#38
#40
#41
When is the next Mooty Laguna Instructor Day.
I have always wanted to drive on that track. How far in advance do you have to book Mooty as the instructor for the day?
#42
#45
