Shifting problems
#31
this was cured by the steel synchros ... and several $k's ...
#32
#33
if the synchros on the GT3 boxes are steel or not ...
just reporting the similar symptoms, cause and resolution!
#34
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
#35
I can certainly understand why people might be a bit upset with this issue, but keep in mind that synchronizers are just like your clutch, they are wear parts. They need to be replaced from time to time, especially if you are racing the car.
good news on steel 3rd - 6th though, we have them here for $160 each, which is a steel in comparison to Porsche prices. The 2nd gear is still incredibly high at $1510 per gear, but you only really need steel in the second gear set anyways.
Let me know if you need any of these we have a couple of thousand of them.
Warmest Regards,
Erik Johnson
GBox Performance Transaxles
(303) 440-8899 work
Warmest Regards,
Erik Johnson
(303) 440-8899 work
#36
I just rcvd a great phone call from Orbit. Cable end of one of the cables was broken (not obvious which is why Braman never caught it). Roger H will call back to see if he can just screw in a new end which would mean the car would be ready in 10 minutes. If cables have to be replaced I requested the cup car cables to be installed.
As a side note, Orbit also took out the gear oil to analyse and see if my synchros were worn but he stated that it was about the cleanest gear oil he had ever seen. (I've replaced it twice since new when in for yearly service but not beyond that)
Either way I'm going to Sebring this afternoon and can still make the 5, 6:30 and 7:45 Pm night sessions![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
#37
Erik, great news and hope it gets fixed. Would be interesting to know which part failed so we can all keep an extra around. Cheers and good luck at Sebring, I'm jealous (it's -5C outside here in Toronto).
#38
well, I got excited too early, the shifter cable indeed had an end that was kaput, and we replaced the cables with 2004 RSR shifter cables, which Orbit just had layiing around, even better then the "regular" cup car cables that are a common upgrade, but........ the car is still shifting really tough and notchy. Have to put some force to shift the gears, so after trying to adjust the shifter cables, we will try again tomorrow. Still do not thing it is in the gearbox, but now think its also something with either the pressure plate or the clutch. We bled the clutch but that made no difference, but the normal lightweight flywheel rattle when car is idling is now present in other gears when you just lay off the gas at around 3-4K rpm and let the car coast. Possible a broken pressure plate. Will know more. Missed the first day of 48 hours and tomorrow is not looking good, but remain hopefull
#39
Erik,
Sorry to hear about your troubles but you are now in good hands and it sounds like Roger is making progress. If you do make it out to Sebring before the end of the weekend be sure to stop by our tent and say hello. We're enjoying your Florida warmth and I look forward to returning to Colorado with a sunburn.
Regards,
Matt Monson
Regards,
Matt Monson
#40
Thanks Matt,
I still hope to get it resolved if only we knew what it was. Roger will give Brian Copans a call in the am too just to see if he has any suggestions. But since Roger has also rebuilt 100's of transmissions, he's 95% sure it's not the synchronizers. Fluid that came out was perfect, and even reverse is now tougher to get into.
#41
As I mentioned earlier, it's probably the clutch. In my 993TT which uses the G50 gearbox, I also had an issue where the gears felt notchy; the clutch was checked and came out with flying colours. I insisted on replacing the clutch disc and pressure plate and it returned to buttery smooth shifting after. I don't know if it was the throwout bearing, the clutch assembly or something else, but the replacement cured the shifting issues.
#42
Yeah, car is going in on Monday for clutch replacement since we have nothing else besides the gearbox itself. But since it has gotten tough to shift the car even into reverse, i tend to agree with you. Will know more on monday, will miss the 48hours this year for the first time in many years
#44
Gearbox was dropped today, clutch crumbeled into little pieces so hopefully tomorrow we're back in business. Now I'm considering if I should replace the Diff "while we're at it". Need to do something to keep up with the new RS's coming out with the short Diff.
