RS titanium exhaust
RS titanium exhaust
New details (under "Features" for RS) up on the Porsche website suggest only Ti in the RS exhaust is going to be the tailpipes - not the center section as has been speculated. Photo is from the RS section.
Also interesting to note that the car weight is omitted.
Hope to be proven wrong on this one and wouldn't be first time website is wrong (they're still showing plastic rear window as standard in US), but with both the order guide and the website giving same info it looks like all we're getting are a set of bolt-on Ti tailpipes.
From RS "Features" on Porsche website:
The lightweight sport exhaust system in the 911 GT3 models consists of two front silencers, two catalytic converters and one rear silencer. The exhaust on the 911 GT3 is painted black, whereas on the 911 GT3 RS it is made from titanium. The system’s large volume reduces exhaust back pressure to increase power.
From the order guide:
450 hp, 317 lb ft torque - 3.8 liter horizontally opposed 6 cylinder, aluminum alloy engine block & cylinder heads, titanium connecting rods.
Rear mounted engine. Dry sump lubrication system with external oil tank and oil cooler. 4 overhead camshafts, 4 valves per cylinder,
“VarioCam Plus” variable inlet and exhaust valve timing. 2 stage resonance induction intake manifold. Cylinder specific knock control. Sport
exhaust system with 2 titanium center tail pipes. Dynamic engine mounting."
Thanks for posting, it would go against what they said earlier about a titanium exhaust that save weight.
Someone shanged their mind?
This would be pretty pointless, but that makes it more justifyable to replace the final muffler with a Sharky.
The website also says this, "The dual-tube tailpipe is integrated into the center of the body. The silencer and tailpipes are made from lightweight titanium. Their diameter is 5 mm larger than those on the 911 GT3. You can see, and hear the difference."
2010 GT3RS Dealer Release quote:
"To save weight (approx 13lbs), the rear silencer and tailpipes are made of titanium."
So I am expecting my center muffler to be Ti.
Rhonda - is M&M or Akrapovic building the OE exhaust? You know what the facts are?
Dropping the Ti silencer, which I understand was to made by Akrapovic and therefore not cheap, would be a quick way for Porsche to juice margins on US RS's.
Is the length of warranty coverage for the exhaust system any different in countries receiving the Ti silencer compared to what PCNA has to provide in the USA?
I saw the dealer release as well but that came earlier. I hope I'm wrong but lack of a posted weight on website for US cars (ROW has posted weight) and all the references to Ti tailpipes suggests otherwise.
With that said, the US online configurator indicates: Standard Features: "Titanum end pipe and muffler" and Technical Data shows 3020lbs. Does the info show other incorrect data for US vs ROW cars, yes. But the exhaust and weight should apply equally to all specs.
No need for concern based upon any info I can gather?
AH- Follow-up edit. I see where you were getting your info from. Now, Click "Features ->"Concept"->"Aerodynamics" and voila..."The dual-tube tailpipe is integrated into the center of the body. The silencer and tailpipes are made from lightweight titanium. Their diameter is 5 mm larger than those on the 911 GT3. You can see, and hear the difference."
Hey! Any darn fool knows to look under "Aerodynamics" for their exhaust info!
bah who needs ti... if you want light this SS one is 11 pounds:P
http://www.sharkwerks.com/products.php?pid=255
Of course the cost would be much higher, and it might not be marketable because of that
Platinum Dealership
pretty easy answer would just be to examine under the blouse of the GT2 right? similar set up I'm guessing...LOL if the US cars only got the Ti Tips. that'd be lame.
No doubt the same ti tips Porsche is now offering for sale.
Anyone that attended the UK launch take the time to look?
