LSD buster
#122
GT3 player par excellence
1/29-30 is HOD.
is advanced open passing?
i can run race prepped, but then you guys can play with me.
i can do advanced but i find most ppl point by too late.
#124
ugh...
ok, maybe i can learn to be patient.
damn, i dont have horn on the car anymore.....
get your avatar changed. looks like you.
#126
Lar, gald you have a 2 wheel drive GT3 again! Now I can't relax with you on the track
#127
Guys, I have heard that putting in an LSD came produce more understeer, is this correct? What is your experience? Any change in handling characteristics at all?
#129
Race group is good for hod. No pointbys well at least never got blackflagged like in advanced grp. I remember Mooty and I did some passing that made someone at the track nervous(lotus club) but they approached mikymu bout it. Weird. Mike
#134
Admin
plus1 understeer especially in wet or in tight corners.. but that is normal ..basic physics.
btw Vic even with Motorsport steel internals if you go for the later Cup clutch pack it is very aggressive, the older one (*pre 2003) that you probably have is better for mixed use.
Mike drives flat out, cuts through corners so he doesn't notice
#135
if you go for the later Cup clutch pack it is very agreesive,
T1 at VIR was undoable, the hairpin at Sebring was OK.
Initially I had huge clunking noises when i came off the track hot, when thecar cooled it went away.
They told me that should not happen anymore, as it is now less "tight'.
