LSD buster
Sorry for the thread resurrection.
Mike, has your opinion on the diff changed now that you've given it more street & track time? In choosing between yours and another LSD I'd value actual user experience more than anything else.
I'm outside the states currently and won't have the luxury of shipping my existing diff across the ocean for a rebuild. Will likely go for a whole diff purchase and have my local tech transplant the ring gear (and spider gear too?) onto the new diff.
FWIW my car is 70% street and 30% track and I'm leaning towards a lower preload (60lbs) and similar lockup values as yours.
Make sure your mechanic know what they are doing. It's not a straight forward replacement and you need to shim and preload the aftermarket LSD to fit the case or it will cause $$$$$$$ damage. When I was looking for someone to install an aftermarket LSD in my RS, ALL the Porsche dealers in the SF area refuse to do it and they said they do not have the expertise. I finally located a former Porsche Motorsport mechanic that will shim and preload the after market LSD for $3K+ which includes transmission removal. That's why I chose to rebuild the existing OEM LSD and save myself the money and hassle of removing the transmission etc.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I missed this? Wow!
Miky this is amazing. It is seriously an easy job if you have the proper instructions.
My guess is that 50% or more of the 996 and 997 GT3, GT3 RS and GT2 have a worn out and useless LSD, and that 50% or more of the owners don't know it.
My 996 GT3 LSD was fried at just 2,000 miles with two track days only and a few autocrosses (8 laps per day autocrosses). I installed the 996 GT3 Cup unit, and problem solved.
It is great to rebuild the stock diff with new internals. I spoke with Paul Guard at large on this issue, as I was about going to do the same to my 997 GT3 RS, but sold the pumpkin.
After reading this I went out to the garage and did the "spin test".....
My wheel spun as freely as mikymu's initial video showed, and the car only has ~9800 street-only miles on it....
I wonder why this stock Porsche GT LSD wears out so easily....
again... excellent post all the way mikymu!!
And the practical reality of it is any shop that is good enough to install an aftermarket LSD and get the ring gear set right is a shop that could also rebuild the LSD for you. I put rebuilding an LSD of a difficulty of about a 2 on a scale 5 with installing a complete differential a 4.5 or more.
Mikymu,
Excellent, thanks for the write-up!
A quick question for you: How did you get the car on the block like that? Did you have to jack up the car at the upright so you lift up the wheels while jacking? I'm trying to figure out what's the easiest / best way to do this just for standard maintenance.
Thanks!!
Thanks!!
I missed this? Wow!
Mikymu,
Thanks!!
Thanks!!
The spin test is not accurate. As stated in the article, the factory static load break away torque is very low. You can get a better estimate with the rear wheels off and using a proper range torque wrench but again the shop manual procedure to check this is with the LSD removed (bench test).
