Braille batteries
So, Porsche's optional lithium battery is $1700 and the Braille is about $250 from Suncoast. The weight savings are close and you would have your stock Porsche battery.
Does anyone have the scoop on the Braille?
I'd been using my 12 lbs. Braille battery for 10 months, I always keep it connected to my Porche's battery conditioner, no problems so far.
My car sees very little use beside track use, I expect this battery can last like this for 3-4 more months. Yes you have to be careful not to leave a door open or a parking light on, since it will get discharged very fast (happened to me a couple of times but after a jump every thing was OK.) With $1700 you can buy 3 Braille batteries ant save $1000.00!!
If your car is going to be used as a DD them that's another story, I won't recommend it!, but also in that case a lightweight battery makes no sense.
Location: Trying to be the driver my car wants me to be
What is the longest you think the car can sit without needing a charge?
I used the Rennline mount kit, not sure model but you can contact them:
Questions and sales support:
orders@rennline.com
32 Catamount Dr.
Milton, VT 05468
PH: 802.893.7366
F: 802.893.7311
Yes maybe can work as an all season DD, but for how long? I don't think it would be safe, I try to minimize the battery use (I don't even turn the car off when refueling for gas).
![](http://i42.photobucket.com/albums/e324/mkozink/Vorschlaghammer/P1010072.jpg)
Yes, I now remember that one is the mount kit i used. Two years, wow!! that is good news for me!!
Nice find. I will be getting this battery soon ... it will be the 6 lbs racing battery. I don't think I need the carbon fiber case lol. The regular 6 lbs version cost $175. How much does the OEM battery weigh?
The carbon fiber Braille version weighs the same, it is just for show (basically some thin CF paneling glued on top of the regular one. They are the same as Deka, supposedly, and the Deka versions maybe another 30% or so cheaper. The stock battery I just weighed at 42.8 lbs. I personally use the Odessey PC680 with the aluminum mounting kit from Rennline; I also added the disconnect switch which can be attached to a cable so it is accessible at the top of the hood. I believe my PC680 comes in around 18-20 lbs. I seem to remember saving 22 lbs with my battery and the mounting kit and switch.
I have used the Braille 12 lb version in my Lotus cars and it was borderline; you really had to charge it if you leave the car sitting more than a day or two. The 6 lb one I would not recommend except for track use. Go with the Odessey or at least a 15 lb Braille battery. Either one will match or exceed Porsche's overpriced unit. Also, I use my PC680 during winter.
I am not certain but I believe the Deka ETX14 is the OE version of the Braille battery. There are a number of versions of this battery to choose from as the attached pdf indicates.
This has all been discussed before in the VW Vortex forums (and many others to be sure). East Penn is the manufacturer.
Shop around locally but you can probably find one for around $70-$80.00.
The main caveat is to keep a trickle charger on it when not in use.
I had an Odyssey PC680 (with a battery kill switch) in my Miura S. The PC680 weighs about 14 pounds.
We also had an Odyssey PC925 (since 'upgraded' to a PC1200) in the wife's Dino, also with a kill switch.
The old cars don't have a lot of electric accessories and the Odysseys work great (at least in SoCal) as long as they are either regularly driven (50-ish miles in a two week period seem to be enough) or the battery kill switch is turned off... until you have an electrical issue. The smaller/lighter ones have virtually no reserve, so if you suffer an alternator problem, and you're driving at night you can easily find yourself on the side of the road waiting to AAA - as my wife did 3 weeks ago.
Basic Sponsor
I've had 2 crap out on me on the P racecar. They replaced one of them. Worth the effort on a racecar...not on a street car IMO. MUST keep them charged.
![](https://rennlist.com/forums/signaturepics/sigpic53041_8.gif)
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
