Single-mass flywheel noise question
Received 1,843 Likes
My understanding is that the additional noise created by single-mass flywheels over dual-mass flywheels only occurs when the transmission is disengaged, i.e., at idle. The is no additional noise created by the single-mass flywheel/transmission under power. Is this correct?
I've done a search on the forum and found some threads that support the above but none are entirely clear and most are dated.
Thanks.
Thanks.
According to this post over at renntech
The rattle you hear is from the gearbox and is normal with a single mass flywheel. At idle the individual cylinder-fire pulses are passed through the flywheel to the gearbox (with the clutch engaged) and those pulses rattle the gear lash/play in the gear train. A dual mass flywheel effectively has a rubber(or otherwise) damper in it which smooths out the pulses and reduces the gear lash rattle."
http://www.renntech.org/forums/index...howtopic=21855
jvaleski (04-23-2021)
The stock FW has rubber between the plates. The noise you hear is the normal sounds from the car that are not isolated by the rubber. Nothing is loose. IT is just the sound of a car with a proper F.W.
My wife hates the sound but I just make sure I have the peddle depressed at lights and all is well. It is a great mod! 17pounds the crank does not need to turn. 1,-3 is unreal.
BTW: that is a wicked avatar.
It's a no-brainer (except for Porsche warranty?).
Having had to replace a dual-mass flywheel in both mine and my wife's Boxster Ss, I also prefer to not have a flywheel be a 'replacement' part, especially at $1200+.
That, and hating sunroofs, sealed the .1 RS for me.
Dealer installed my DME and SharkWerks bypass. That doesn't mean that PNA will be happy.
Back in June, MJones posted a TSB (3/08 1359 Dated 5/18/2009) listing PNA policy/excuses under the thread "New TSB re:RMS"
Forewarned in forearmed.
just need the right dealer. I had PCCB rotors replaced for <$2400 because of a dealer that understands I am their customer and fought the fight. The Porsche rep will always as no. They have done the mod to a number of cars.
GT3 player par excellence
Thanks.
Thanks.
it's not very loud at all. after 100 miles you will never hear it again (you will get used to it)
Thanks.
Thanks.
When that $1700 Li-Ion battery pukes because it's overcharged (with a conventional "tender" for lead-acid batteries) or 100% discharged (radar detector) don't expect the parts guy to push a new one across the counter with a smile and a hardy handshake.
When you damage one of those centerlocks, don't expect PCNA to carry them in stock in the country. They barely carry wiper blades in stock.
What this has to do with a clutch rattling in the basket, I dunno, sorry ... : ) ... just thinking out loud ...
On my RS, the "rattle" is of course there at idle with the clutch in, but only after the car warms up a bit (not sure why). Once up to temp, I often also hear a clear (but more subdued) rattle at low RPMs when powering away from a stop. I've come to actually like the sound because it just fits the hard core nature of these cars.
BTW Carrera GT, I think the Li battery has some protection built in to ensure it never discharges completely.
