Lightweight HL Question
600 Lightweight Headlights
"Halogen headlights (without headlight washer system). Reduces weight from standard Bi-Xenon headlights with headlight washer system by approximately 13.2 pounds."
Does anyone know how much of the 13.2 pounds is washer fluid?
If the washer fluid reservoir is empty, I wonder how much difference there is between the weight of halogen and Xenon lights?
Still plays with cars.
Isn't the fluid reservoir the same one that is used on the windshield isn't it? My car has only one filler. I find it hard to believe that the weight savings is there. On the other hand having experienced them first hand, the halogen lights suck for night driving.
Regardless, Xenons are pretty heavy.
Bob is right - the washer fluid reservoir supplies both the winshield wipers and the headlight washers. The washer fluid capacity is 6 liters - I guess about 1 1/2 gallons. So there must be a difference of 13.2 lbs just for headlights not including washer fluid. I guess you could drain most of the washer fluid and save an additional 12 lbs or so. So can save total of approximately 25 lbs by going with halogen headlights, draining washer fluid, and driving only in daylight hours.
