997 GT2/GT3 Forum 2005-2012
Driveway and front lip - Any ingenious ideas?
Old 10-29-2009, 12:40 PM
tcsracing1
tcsracing1's Avatar
Originally Posted by LeonardoC2S
How about this from Griot's Garage: Driveway Curb Bridge (I don't have any experience with this...just see it their catalog.)
http://www.griotsgarage.com/product/...curb+bridge.do
much better.
i was going to reccommed small abs pastic tube and concreted over with no permits
Old 10-29-2009, 12:53 PM
jugger911
jugger911's Avatar
This was one of my deciding factors when I was purchasing a house about 10yrs ago. I refused to even look at a house if I had to worry about rolling down the driveway as I washed my car. It would have to be one hell of a deal for me to buy one that didn't have a flat drive. Working at UPS, you wouldn't beleive the set-up's I used to see back when I delivered.
Old 10-29-2009, 12:57 PM
sws1
sws1's Avatar
That Griots Garage thing is VERY cool. It's pretty much what I envisioned in my head.
Wonder if they'd take it back if it doesn't work. Or I could make my own and nail it to the road.
Old 10-29-2009, 12:58 PM
sws1
sws1's Avatar
Oh - and to some extent, it's less about the scrape on the car. (I can replace the plastic.) It's the nasty black streak that is left on the pavement.
Old 10-29-2009, 04:30 PM
Tom B
Tom B's Avatar
The griots ramp won't work for my cars/driveway - I recently bought a second house and had to over come the height difference of the road to the driveway.
The only way I can make it into the driveway is with 2" X 12" X 40" ramps. The griots ramp is only 16" wide, the over hang, or distance from the leading edge of my front tires, to the nose of my cars is minimum of 32" and up to 37". I have a elevation difference of 5" from the road to my driveway. Of course, the other factor is how low the front of the car is.
Since I don't use the house on a daily basis its not much of an inconvenience.
Old 10-30-2009, 04:21 AM
andrew2008
andrew2008's Avatar
This is exactly what I did. I put in 2.5" PVC pipe and covered it with concrete. Every few days the pipe gets plugged with leaves and stuff being washed down with the water so the water just flows over the ramp. My neighbors are cool and nobody has complained.
Old 10-30-2009, 05:52 PM
Arrwin
Arrwin's Avatar
Originally Posted by DavidNR
I have a similar problem. Gotta get it right or scrape. With a new car coming soon with a lower front lip I have been lookning at this. May or may not work depending upon the type of curbing.
Seems like a great idea. But I can't help to think leaving that on the streets anywhere NYC for $300, it'll be gone within a week. Unless you plan on moving it in/out everytime...which wouldn't be too bad I guess if you don't drive the car that frequently.
Old 10-30-2009, 06:35 PM
Leigh2
Leigh2's Avatar
I had the same problem with a previous house and had the end 3 feet of the driveway hammered out and replaced with a lower profile version. Required a permit and had to be reinforced to the city's specs but sure saved a lot of aggravation in the long run.
Old 10-30-2009, 07:15 PM
stevecolletti
stevecolletti's Avatar
"When bolted together the ramps weigh from 120 to 170 pounds so they stay put."
Carrying that off is dedication to their 'craft'.
I guess you could add one or more of their 4 feet extensions so that the criminals would have to carry off something that's 20 feet long and weighs over 200 pounds.
Old 10-30-2009, 08:08 PM
jimxyz
jimxyz's Avatar
my driveway is a nightmare - the angle from the street to the sidewalk is pretty steep and about 3 feet long, if I come in at a very precise angle and the exact speed I can just barely avoid scraping - going out is even more difficult. Griots solution would work if the ramp was longer. I may build a plywood ramp and tell the neighbors its for the kids skateboards
Old 10-30-2009, 08:21 PM
Glock Guru
Glock Guru's Avatar
Hold out for the next federal goverment bail out program. "dollars for driveways".
-Troy
Old 10-30-2009, 10:37 PM
Md11skipper
Md11skipper's Avatar
Why don't you consider the Cargraphic or KW lift kit, then you are safe for any driveway.
Old 10-30-2009, 11:08 PM
PogueMoHone
PogueMoHone's Avatar
Buy an earthmover!
Old 10-30-2009, 11:59 PM
DavidNR
DavidNR's Avatar
Arrwin,
I was wondering about moving around from crossing it, you know it will move. Bet you could put a few anchor bolts in and solve both problems.
Old 10-31-2009, 01:34 AM
wwest
wwest's Avatar
A pair of old time steel skate wheels come to mind. You know, from the old clamp on your shoe soles skates. Personally I took the bottom spoiler edge off of my '01 C4 and stored it.
Quick Reply: Driveway and front lip - Any ingenious ideas?
