Need help removing lower dash
I've removed all the screws and have access to the wires behind the driver's side lower dash.
I don't know how to remove/transfer the ignition. Also, don't know how to remove foot light/wiring.
Any insight?
Any insight?
The diagrams in this pdf might help, otherwise, just go talk with a tech at the dealer. The steering column and ignition assembly are "fortified" to resist would-be hot-wire attempts from people who believe what they see in movies where all it takes is stripping the red wire, twisting it around the white wire and tapping the green wire to ground to kick over the starter ... : )
http://www.porsche.com/all/media/pdf...97_KATALOG.pdf
How did this workout?
