997 GT2/GT3 Forum 2005-2012
Front Lift System?
Old 09-29-2009, 01:01 PM
flash1034
flash1034's Avatar
So 30mm wont make much difference will it. Youre going to scrape anyway.
Flash
Old 09-29-2009, 10:11 PM
10 GT3
10 GT3's Avatar
It is also 30mm at the tip of the front lip. At the axle, it is only 20mm. This puts the height the same as a stock Carrera. This means that you will most likely ocassionally scrape. Remember that a front lip is only $200-250. Porsche actually considers them to be a "disposable" part. The aftermarket lift systems like Cargraphic also cost the same, yet lift higher for the same price. I originally had this on my November and pulled it off because it simply doesn't make economic sense.
Quick Reply: Front Lift System?
