MK2 GT3 vs RS weight....Hmmm
With lower gearing and more power (and more rubber), I would expect RS to post a larger acceleration inprovement than that...
I read that the new 2011 RS
0-60: 3.8 seconds
Also more power + more grip + shorter gears + LWFW = FASTER NEW GT3RS
If its lighter even better, but even if it weighs the same as the new GT3, the above will make its a faster track car overall.
ISN'T THAT THE POINT OF THE GT3RS?????? FASTER TRACK CAR!
0-60: 3.8 seconds
GT3 was tested at 3.7 0-60 by Car & Driver IIRC, so with shorter gearing and slight power bump the RS should probaby see 3.5 or so, and noticeably quicker 1/4 mile time. Wonder what the trap speed will be? I know these are not intended to be "drag cars" but the times give useful info.
longer 6th gear, same ratios as the 2007 GT3, new R&P.
2010 GT3 RS
325/30R19 MPSC
Gear, Ratio, Max Speed, RPM drop
1st 3.82 45
2nd 2.26 77 5000
3rd 1.64 106 6200
4th 1.29 135 6700
5th 1.06 164 7000
6th 0.88 197 7100
Final Ratio 3.89
Redline 8500
2007 GT3 / GT3 RS
305/30R19 MPSC
1st 3.82 50
2nd 2.26 85 5000
3rd 1.64 116 6100
4th 1.29 148 6600
5th 1.06 180 6900
6th 0.92 208 7300
Final Ratio 3.44
Redline 8400
2010 GT3 RS
325/30R19 MPSC
1st 3.82 45
2nd 2.26 77 5000
3rd 1.64 106 6200
4th 1.29 135 6700
5th 1.06 164 7000
6th 0.88 197 7100
Final Ratio 3.89
Redline 8500
2007 GT3 / GT3 RS
305/30R19 MPSC
1st 3.82 50
2nd 2.26 85 5000
3rd 1.64 116 6100
4th 1.29 148 6600
5th 1.06 180 6900
6th 0.92 208 7300
Final Ratio 3.44
Redline 8400
I don't believe a peak horsepower increase of 20 hp (or even 35) can make a difference as big as 0.6 seconds. I think the new engine's torque curve must be a lot beefier than the 997.1 engine throughout the revband. Can't wait to drive one!
FYI: August issue of evo mag tested the 2010 GT3 0-100 time at 9.2 seconds, and 1320 feet - 12.4@118.
In the 4 second range the 0-60 time is usually 0.2 seconds faster than the the 0-62 time. In the 6 second range it is about 0.3 in most cases, and this delta increases as do the 0-60/62 times.
My 2009 JCW is listed at 2,700 lbs, and mine has almost no options. With a full tank of gas it came in at 2,600 lbs!!!
I wish Porsche was that honest.
0-60: 3.8 seconds
0-60: 3.8 seconds
In the current issue of Road and Track, the got a a 1320 of 11.8 @ 119.5. That is only a 10th behind the fastest 997TT they have tested and quite a bit faster than either of the MKI RS's they tested.
You guys forgot that the RS is 44mm wider, which adds weight. Also improves performance though.
Maybe the power improvement added a little weight too?
My question is, how will Porsche's 3.8 RS with 450hp compare to Sharkwerks 500hp 3.9 997.1 GT3.
The gearing difference will be felt. Used to work wonders on the older air-cooled cars; I wonder if it ultimately would be a practical and worthwhile mod for the the (track-toy) GT3 II ..
