Lithium Ion Battery Cost ???
Since there is no order guide yet, what do you guess that Porsche will charge the consumer for this hi-tech lightweight gem?
Me thinks $650...
Me thinks $650...
Not that bad, if so.
This was the closest I could find.
http://www.jerrybickel.com/batteries...powlr48ck.html
The ones from Voltphreaks are in the $1,200-$2,200 range (my favorite is the VPR-S40)
Porsche could easily charge in the same range. They are less than half the weight with same capacity and higher CCA, and longer lasting.
22 lbs removed just from the battery, plus door panels, Ti exhaust, and LWFW, this car will be much lighter than any previous RS has been compared to the standard GT3.
In the supertest article for the gt3 a couple months ago, the lithium battery appeared on the options listing for the blue car that was tested. Its price was 1904 euro... Im guessing about US$1900.... Sure its in German but you can tell whch refers to battery...
Attachment 379809
Attachment 379809
It will be much harder than it would seem to get a US-Spec RS under 3,000 pounds with only careful ordering of factory options (read impossible without aftermarket help).
GT3 player par excellence
i dont know. i want a *** heavy big battery b/c i dont like trickle chargers, or jumping the car.
my race car was stuck in the trailer dead battery. the effort i put in to get it out .... i almost decided just to sell the damn trailer with race car in it.
yes, i have winch, but ................ loooooooooooooong story. i want standard battery.
http://www.rockracingbattery.com/specs.php
^ thx. i am looking at the web site now.
The price listed here in South Africa for the Li battery option is R24,000 ($3k). As we usually pay about 50% more than the US for options, my guess is that it will be around $2k for US cars.
Porsche's published curb weight is presumably for a car with standard options. So ordering the lighter battery, PCCB, a/c and radio delete, lightweight buckets (ROW), and removing the rollcage could take quite a few lbs off the published weight.
Just want to mention, that the Voltphreaks battery features a low voltage cutoff, so that you will never be left with a stranded car with a dead battery. The battery that we recommend for most Porsche's is the VPR750, which weighs 5.25 pounds, and contains the low voltage cutoff feature. Before the battery is completely drained, it will automatically disconnect itself, leaving enough power to still start the car a couple of times (in case a sensor or computer is left on, etc).
- Tony
