1500 frames per second Super Slo-Mo
Amazing footage, thanks for the link. At about 1:34 you can see Hamilton flat-spot his left front tire, then 6 seconds later you can see the flat spot roll by on the tire surface. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Also amazing to see how much lateral "float" there is with the tires on the rims and how much sidewall stress there is, even with those small stiff sidewalls.
