Yep, Craig is your man at Rennstore. I bought my pads from him for the same set up. PCCB calipers with steel rotors.
As a side note, when you check the thickness of your front pads, make sure you look a them from below. The leading caliper pistons exert more pressure than the trailing ones, so they wear out on the bottom first. Z
