Need a measurement for ramps please
Needs to Get a Life
Hi
I am going to order some custom ramps from race ramps.com for my new trailer. The car is in the shop and I won't back back over there for a few days. Would someone mind measuring their car as outlined below...
I need the vertical distance from the ground at the elevated end of the yard stick (or what ever you use that is 36" long) so I can get the length of the ramps correct. Have the yard stick just touch the bottom of the front spoiler. I will build a little cushion into the measurements that I order so please give me exact. Thank you, thank you thank you!!!!!!
Hey, can't measure the height for you as I don't have a 997 gt3 yet but I know that the maximum approach angle for the 997 gt3 per Porsche specs is 5.6 degrees (based on standard suspension height settings) and therefore a 36" yardstick would hypothetically sit 8.92cm or 3.5" off the ground...
Sin 5.6o= O/91.4 (calculation in centimetres)
O= sin5.6o x 91.4
O= 8.92 cm or 3.5"
Hope this helps you....
Chris
O= sin5.6o x 91.4
O= 8.92 cm or 3.5"
Chris
Needs to Get a Life
O= sin5.6o x 91.4
O= 8.92 cm or 3.5"
Chris
O= sin5.6o x 91.4
O= 8.92 cm or 3.5"
Chris
Needs to Get a Life
A tad over 4" on a stock GT3 RS, with corded A6s on the front This will change a lot if you get a full width ramp because the center projects a lot further than where the wheels are.
I built my ramp extensions a bit different than most people. Ramp goes from 0 to 3.5" in the first 12 inches and then level for the next 3 feet. Another 3.5" jump and level for the next 4 feet. Featherlight ramps sit on that. This allows me to stop and check alignment without even engaging the parking brake. Also makes it easy on the clutch to get going again.
I bought the TR-5 and I'm returning them. They're perfect, but they are too long to be stored in the SUV. I'm getting a custom set with the same dimensions as the TR-5, but cut in half and just a little longer (6' instead of 67"), same dimensions on everything else.
Needs to Get a Life
Thanks for the post.
If they are new just ship them to me. I will buy them.
The TR-5 cleared my GT3 RS and my super lowered Boxster BSR. The custom set I ordered costs close to $500, but worth it as these ramps are something of a new level.
They're very light for their size.
The only problem I have with them is that they're 67" long, and I use an open trailer, so I have to carry them inside the SUV, and the SUV has a small trunk, so I have to drop both row of seats. I cannot open the rear hatch with the trailer hooked, so floor jack, tires,tools need to be accessed through the rear doors.
Just place an order on-line, it's easy. I have to keep these ones until the new ones arrive, and then return them for a full refund minus shipping.
