997 GT2/GT3 Forum 2005-2012
2010 GT3 question: 380mm steel brakes
Old 04-08-2009 | 08:43 AM
viperbob's Avatar
viperbob
Former Vendor
Originally Posted by _rocket
Thanks to the recent '2008 Cup Car' thread, just look at what brakes cup cars are using...
Yep, same old calipers that came on the 996 GT3s.... To bad. Brembo has a much better 6 piston bridged caliper that matches the bridged rear on the 7 GT3.
Old 04-08-2009 | 09:27 AM
Turbo4ever's Avatar
Turbo4ever
thats why they offer you the PCCB
Old 04-08-2009 | 09:34 AM
Turbo4ever's Avatar
Turbo4ever
Are these 2-piece brakes floating type? Normally, floating brakes have bolts all the way through, but it appears that the new GT3 brakes only have bolts behind the rotors (hidden) so they must be fixed type, right?
The 997.2 GT3 comes with 1 piece rotors and after looking at the PCCB and Cup rotors, those stantard one looks cheap.
Old 04-08-2009 | 11:09 AM
KINGSRULE's Avatar
KINGSRULE
I believe they are exactly the same rotors that come on an R8.....
Old 04-08-2009 | 03:09 PM
_rocket's Avatar
_rocket
What? According to the pic in the web special, the yellow front calipers are not bridged either.
Old 04-08-2009 | 03:20 PM
_rocket's Avatar
_rocket
Originally Posted by 911rox
These are in fact a 1-piece unit unfortunately... confirmed by the chief designer dude in the DR interview...
What the dude meant is that the bell cannot be separated from the friction disc because it is pinned, no bolts. But the bell is made of aluminium. When you need to renew your rotors, you have to change the whole thing, not just the friction disc.
Old 04-08-2009 | 03:24 PM
_rocket's Avatar
_rocket
You mean 996 cups? Street version came with 350mm brakes, not 380mm.
Old 04-08-2009 | 06:59 PM
_rocket's Avatar
_rocket
Pics?
Old 04-08-2009 | 07:50 PM
911rox's Avatar
911rox
That is what I meant... they are cast so despite the two materials they are still a 1 piece unit. They don't offer the functionality of a 2 piece rotor, just the weight savings of the aluminium hat... In my book, a 2-piece unit is designed to seperate...
Old 04-13-2009 | 03:03 PM
TrackDays247.com's Avatar
TrackDays247.com
Former Vendor
...and, for us mere non-race team mortals -- designed IMO for savings - ie the rotor ring is replaceable, saving up to half the cost of replacement (vs. theoretically tossing the entire 2 piece away)
Old 04-14-2009 | 12:57 AM
_rocket's Avatar
_rocket
Another thing that should be mentioned is that the rotors (pinned) are not floating type. If you want floating brake discs you have to buy an aftermarket set or get PCCBs.
Quick Reply: 2010 GT3 question: 380mm steel brakes
