A.W.E. Tuning - 997 GT2 Product Development - 14 October 2008
user
Hello,
On Friday October 10th a 997 GT2 was handed to us by a gracious customer looking for added performance. In this thread we will document a comprehensive case study. Our mission is to further prove that nobody takes product development as serious as we do.
As I am sure many of you know, the headers and intercoolers are the same as the standard 997TT. Incremental testing of our A.W.E. replacement components (headers, mufflers, intercoolers) will be done on our Mustang Chassis Dynamometer to show what further gains can be had.
Here is the car as it was delivered to us on Friday.
![](http://www.awe-tuning.com/media/cars/997gt2/997_gt2_1.jpg)
![](http://www.awe-tuning.com/media/cars/997gt2/997_gt2_7.jpg)
![](http://www.awe-tuning.com/media/cars/997gt2/997_gt2_5.jpg)
Currently the car is on they dyno for baseline testing. We use a variety of scan tools for data collection:
Porsche PIWIS Tester
Durametric
Custom G.I.A.C. scan tool
Data points reviewed:
Ignition Timing
Injector Duty Cycle
Boost Pressure
Knock Activity
Air/Fuel
Exhaust Gas Temp.
Intake Air Temp.
Vane Regulation
Mass Air Flow - Grams Per Second
Fuel Pump Duty Cycle
Fuel Pressure
Throttle Position
![](http://www.awe-tuning.com/media/cars/997gt2/997_gt2_8.jpg)
We hope you enjoy this thread. If you have any questions, please ask. We will update as often as possible.
-VIDEO COMING SHORTLY-
Durametric
Ignition Timing
Injector Duty Cycle
Boost Pressure
Knock Activity
Air/Fuel
Exhaust Gas Temp.
Intake Air Temp.
Vane Regulation
Fuel Pressure
Throttle Position
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Thank you, Mike
This thread will be very interesting, please keep posting
I'm doing something similar on my GT2 (I'm on the other side of the Ocean, anyway!)
Upgrade of my car should be finished in a couple of weeks
Will be great to see step-by-step progresses of your project
Cheers,
pmf
Cheers,
pmf
user
engine dyno ~775NM+(570lb/ft) has been causing bent rods on the 997tts so it will be opened for Carillos... AFAIK this and a 800+NM clutch is the only non bolt on stuff required ?
user
Here are a few more photos. We have compiled some very interesting data which we will be posting shortly.
So after we did our baseline dyno runs, we rolled her onto the prototype list for a futher look.
![](http://www.awe-tuning.com/media/cars/997gt2/997_gt2_12.jpg)
We began taking things apart and seeing what we can improve.
![](http://www.awe-tuning.com/media/cars/997gt2/997_gt2_10.jpg)
![](http://www.awe-tuning.com/media/cars/997gt2/997_gt2_13.jpg)
We fitted one of our standard 997TT mufflers to see what a proper exhaust will make on the new GT2. We then did more dyno pulls.
![](http://www.awe-tuning.com/media/cars/997gt2/997_gt2_11.jpg)
![](http://www.awe-tuning.com/media/cars/997gt2/997_gt2_15.jpg)
Stay tuned....
Stay tuned....
user
At engagement there is no chatter or shudder, but it sure is tough to push down!
user
We have yet to glance at any of the trans components....
Tell your tailor that your suits are going to need alteration. Your one leg is bound to get bigger.
user
Here are some data sheets.
Boost Curves
![](http://www.awe-tuning.com/media/cars/997gt2/GT2_vs_700S_boost.jpg)
EGT
![](http://www.awe-tuning.com/media/cars/997gt2/GT2_vs_700S_EGT.jpg)
Intake Air Temp
![](http://www.awe-tuning.com/media/cars/997gt2/GT2_vs_700S_IAT.jpg)
Regarding IATs:
We are measuring via the OBD sensor which is in the intake pipe on both cars. Therefore, we are unable to measure the true temp right before the intake valves on the GT2 where the expansion chamber is. However, look how hot much hotter the IATs are compared to our 700S kit! There better be a lot of temp drop going on in that expansion chamber to make up for the high IATs! Hmmm....
Boost Curves
EGT
Intake Air Temp
Regarding IATs:
Great stuff Mike, keep it coming ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Can you clarify that the "700S" data is from a 997tt which you have tested on a different day ?
If this is the case then what were the relative ambient temperatures for the test as the IAT graph shows the "700S" at a much lower starting point ~87F vs 100F
Can you explain exactly how you do the IAT test on the chassis dyno ? I can see a fan either side which blows ambient air into the sealed I/C chamber in the reverse direction (does this make any difference versus air coming the correct designed direction ?) do you let the car idle for a period of time to stabilise the IAT and get that base starting IAT number (ie 87 v 100F)
TIA
TIA
Toby, I finally gave in and drove my friend's Gt2 at a recent 60-130 event. I am certain you will love the Gt2. Very impressive power deliver even in stock form, and the suspension is fantastic
user
Can you explain exactly how you do the IAT test on the chassis dyno ? I can see a fan either side which blows ambient air into the sealed I/C chamber in the reverse direction (does this make any difference versus air coming the correct designed direction ?) do you let the car idle for a period of time to stabilise the IAT and get that base starting IAT number (ie 87 v 100F)?
Please also see here for more IC testing info:
http://awe-tuning.com/pages/info/con...cfm?content=63
Hope this helps...
