Have Any GT3 Owners Installed A Cup Car Gear Box ???
GT3 player par excellence
Not so easy to change the gear box, I'm told. The 997 GT3 is basically the same car as the 997 GT3 Cup Car. The gear box is interchangeable, but from what I understand, the Cup Car gears are already pre set. They're lower and a lot closer. You don't have the top end, but then, I've never driven 190 MPH anyway.
Basically, you'll be in 6th (instead of 5th) on the back straight of the Glen.
Does anyone have first hand knowledge with this set up?
you can physically put the 997cup sequential in the street car, but you would need the ecu to control the ignition cutt for full throttle shifts and also the huge shifter assembly that stands twice as tall as the stock shifter.
For what it is worth I have installed the 996 Cup tranny in my 996 GT3 and it transformed the car. When I track the 7RS the difference in gear ratio's is tremendous. The cup tranny keeps you in the power band, the down side is you are very very busy shifting. I would highly recommend it if you can directly drop a 996 cup box into the 997??
I did the Cup R&P and an LSD. Well worth the money for me. The LSD is a bit harsh for the street when it is cold, but it is driveable. The extra grunt in second gear is just what I needed for autocross. Cost a few $$ but not quite 10K.
