Tracking new 997 GT3 - Change brake fluid?
Hi all,
I took delivery of a 997 GT3 a few weeks ago and would like to track it since my 964 is in the middle of getting rebuilt.
Since the car is brand new, I would assume I don't need to change the brake fluid, but is there anyone who thinks otherwise? I've got PCCBs on it.
I'm on a mission to get 2,000km on the clock before the weekend! GAME ON!!
Platinum Dealership
make sure you've bed in your brakes otherwise there is a good chance with the stock fluid you're at risk for getting green fade...most likely in the second session of the day
Super Moderator
Needs More Cowbell
Needs More Cowbell
I would recommend bleeding them as well.
Stock fluid in lower run groups should be OK, but make sure you can recognize the onset of brake fade/fluid boil.
Still plays with cars.
If the car is new then you don't need to flush. Most PCA regions insist that brake fuid be no more than 6 months old.
Stock fluid will be ok in beginner run groups. If you are a more advanced driver, use a racing fluid like Motul 600 or 660 RBF, or Castrol SRF. No downsides but they resist heat much better than the factory fill.
Regards
Regards
Regards
Regards
I am not sure on a DIY but if you call CDOC to buy a Power bleeder I am sure they will walk you through with instructions. I am not affiliated, I bought my bleeder from them and I know they will help you. Learning to do it right and do it often is a necessity if you track.
I always start with the wheel further from the master cylinder and move towards it.
