KW Hydraulic Lift System
What's intersting in it for 997 GT3/RS owners is that you can just buy the springs with the unit, without changing the Coilovers, and have it work! Here's the direct qoute for those that are too lazy to check the url:
"The HLS hydraulic lift system is installed in combination with a KW coilover suspension. For vehicles with a standard-fitted coilover suspension, such as for the Porsche GT3 and for the GT3 RS, KW offers a complete solution comprising springs and HLS. HLS is available in two different versions: HLS 2, which is installed on the front axle and HLS 4, which, upon request, can also be fitted on the rear axle, thus making it possible to lift up the entire vehicle. Since bellows are used to protect the hydraulic cylinder unit against stone chipping and dirt ingress, a long service life is assured. The ring cylinder unit is installed between the spring plate and spring."
Here's the url with the info. http://www.porschetuningmag.com/kw-h...r-sports-cars/
