Tough to get into first gear from a standstill?
I had the same problem with my 05 996GT3. If you went to second first it worked fine. I spoke with the Porsche technical director and they agreed to change the box. The second box worked fine, go figure. In any event, it should not happen! You would not tolerate this with your 25K car and why would you tolerate for what we paid?
An update: I took the car into the dealer and was able to replicate the problem with their tech. They adjusted the shifter which seems to have made it better, but it might just be placebo effect.
They had a master tech drive the car and declared it normal. I don't think it's normal, but will give them the benefit of the doubt. At least it's logged in the system in case problems develop in the gearbox later in its life.
Did the master Tech replicate the issue? If he did and declared it normal he is giving you Porsche lip service. I hope for your sake the issue does reslove itself with the adjustment, however I am willing to bet it does not. I wonder why they changed my box with the identical issue??? Good Luck!
Basic Sponsor
I've had the same 1st gear problem. Been looked at by P at least 4x and they keep giving it a thumbs up. But, problem remains.
![](https://rennlist.com/forums/signaturepics/sigpic53041_8.gif)
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
You just saved me some money, but also took away some hope
When did yours start to have this problem? My gearbox was really tight for the first 1,000km (especially 2nd to 3rd), but then loosened up really nicely. It was the best gearbox I've ever had, in terms of "rifle action" feel. Unfortunately, at 7,000km, the first gear started to act up and I'm now at 7,500km.
Basic Sponsor
Mine does same. My 05 M3 did also. Just slightly begin to release the clutch as you slide it into gear and it is smooth as buttter. Once you get comfortable with it , it will be natural. I use this technique with all my cars now. 2nd to 1st works but takes longer.
Thanks for the tip, I'll give it a shot. It is the only thing about the car that bothers me, everything else is 110% perfect.
Thanks!
I don't have such a problem with my RS in 1st. The shift to 3rd would sometimes get notchy. This has improved with time. I have about 8000 miles on it now and the gear box is now finally feeling right. when you go to first, is your clutch depressed all the way? does it make a difference if you have the clutch open for a full second versus immediately before shifting? I think the master mechanic says its normal because it is within their "tolerance". It does not mean a thing, I would keep escalating it with PCNA if I were you.
Clutch is fully depressed and makes no difference if I wait 1sec or 10sec. With the temps in the 30C+ range lately, the gearbox actually feels better and seems to do it less. Hopefully it stays this way! I've got a work order in so if the gearbox continues to act up, I'll keep taking it back until it's right.
Hi
Took delivery late April '11 of 12k mi gt3
Drove 750 mi home
1st gear sucks
Dealer that car w cpo porsche exchange says 2 master techs of their day box is ok
Prior owner complained re same 1st gear user and got bs that adj was that was needed
Now car is at my Pa p shop
They want a new box in it and noted that Porsche knows of issue and thus changed the gear set remedy the issue
Patrick
Drove 750 mi home
1st gear sucks
Patrick
