PCCB protection during wheel change
With the 996's, the PCCB equipped cars came with two wheel placement studs to support the wheel w/o touching the rotors. Make sure the tech uses both.
i personally wouldn't take it to discount tire... rather have a good local race shop with experience and reputation do the wheel/tire changes if it is something you are not willing to do with stud guides, etc...
GT3 player par excellence
you MUST use the studs, if not, you are gambling with a lot of money. if the wind blows or if you breath too hard the wheel will fall off the lip on the hub and your rotor will crack and chip.
as such, i replaced all my wheel bolts with wheel studs
Agreed. They also make for a great conversation starter with the ladies!
So, they *are* in the toolkit? - I never noticed them before, and I plan to mount my new RG5's
this weekend!
this weekend!
OEM stud guides ARE supplied with 997RS.
