Those with LWFW Please Read
I had an RS LWFW and RS Clutch installed in to my 997 GT3. I have done 4 track days on the car with it installed.
I can say the car revs blip up incredibly fast. Heel and toe operation is a snap. Other than a slight chatter sound at idle, I am very pleased with the results.
Well, 1 week after the lwfw went in I was on track at Pocono and the pulley went.
Lost power steering, coolant ect. Could have been a BIG problem if it happened at the wrong time. But all was ok.
Long story short, Princeton Porsche came up and got the car and put in a new pulley, bolts and washer. The RS parts would have taken a while according to them. They are still on order. They torked the sh*t out of it and used plenty of
loc-tight. They truely dont believe it will happen again with the way they put it in.
Other wise
The lwfw is a great mod
Other wise
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
I will let you know if anything happens with the crank pulley, and I will have it checked by the dealer to see if it has loosen up at all.
What a great mod to go along with my Sharkwerks center exhaust delete. Alex is the man! (I bought my LWFW kit from him and got the pulley & bolt part numbers from him also).
Other wise
Other wise
Exact same here; mine is perfect! It was well worth it and my mechanic at the dealer did an outstanding job. We even got the blessing from our Porsche rep since he was at the dealer while this was being done to my car. We used all OEM parts and changed out the pulley and bolt and washer, and installed and torqued every thing per RS specs. This mod has only made the driveablility of my car better, and as stated, makes heel and toe a snap. Even me with my limited experience and talent can do some nice H&T'ing now!
After the pulley went they reinstalled a new one as securely as possible.
It just shifts so smoothly, and the engine revs go up and down much faster and freely; you can just tell that this is how the car was engineered. It makes me think that they did all the testing and engineering based on this flywheel, and that they decided to put the dual mass into the regular GT3 just so they could differentiate the cars some more. I suppose the sound that the LWFW generates is also why the regular GT3 does not have it. To some who do not understand, this could come across as a poorly built car and that something is wrong with the tranny. You really need to understand the benefit and why it is making that sound.
It really is easy to drive this car smooth (from a shifting point of view), and the LWFW does not make it any more difficult. Great mod from all aspects.
The weight of the LWFW is about half of the dual mass one; aprox. 14 lbs instead of 28 lbs.
