OK, So I Need New Rotors Now... Any Suggestions ?
Slotted. Drilled rotors tend to spawn cracks more quickly. The faster and more often temperatures of the rotors change, the faster the cracks appear. This is perfectly normal and not a problem until they get too large and/or start connecting. My drilled rotors exhibited tiny cracks after 1 hard track weekend.
I don't know about the 7gt3 PFC fitment, but on the 6 as iLLM3 points out, the Pagid or stock pads need to be ground down a little to fit (there is a few millimeters less room of pad height on the PFC setup for which the PFC pads are designed) . I never encountered a problem with pads because the PFC pads were fantastic and I did not need to go back to Pagids.
RL Technical Advisor
FWIW,....
We've had excellent luck with an AP racing rotor package w/floating rotors (drilled or slotted) on these cars. Being a real racing rotor, these contain a far superior grade of grey cast iron than OEM and are quite durable using race pads.
These are made in several diameters; 350mm, 360mm (and 380mm) that vary in thickness.
Wrightwood Racing makes these and while they are not the cheapest solution, IMHO there is nothing better. We sell & install a LOT of these things.
GT3 player par excellence
if you want it cheap and good, do search on protosport rotors on this board. i love them and did i say CHEAP.
Basic Sponsor
I put them on a couple of DE's ago, upon your suggestion. So far so good...and I can feel the brakes a little better with the pagids.
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
Man I wish you guys would mention at least ball park pricing to give some idea of the difference.
How much for stock 1-piece?
How much for the Cup 2-piece?
I run PFC Floating Direct Drive Rotors on my M3s and absolutely love them! They are dimpled, not slotted or cross drilled. I get 30-40 track days out of each disc. (Which I find to be a good value, also the car is 3200lbs, but does not develop the velocity of the GT3) I run their 01 Compound Pads for track and the Z-Rated for Street. Will probably buy the PFC Rotors for the GT3, since I never had ANY problems with the PFC stuff.
I was quoted $1700 for the front set. (For the M3 they only run $600) I am not sure where that stands compared to Cup rotors or even compared to stock. If someone know a better source for the PFC products, please let me know.
oem: 700/set - 800/set
I haven't had to replace my 7gt3's rotors yet, but I put the performance friction hats, slotted rotors and pads on my 6gt3 and they were outstanding. I would highly recommend them and am going to go that way when this car needs them. Buy-in is somewhere in the $500-600 more than replacement stock rotors if I remember correctly. I never used Cup or TireRack's rotors so cannot directly compare.
FWIW,....
YOU TOO MOOTY , so many options to try out in the future, hmmm.
using Protosport also, so far, so good, still have an extra set sitting in the garage. When I'm done with them I may just try Performance Friction for one set, just because of the weight. Protosports are 1.5 lbs per side heavier then stock iron rotors, which already weight a ton. But since my rotors seems to last at least 3 times as long as they ever did on my 996, it may be worth it to try some PF
Basic Sponsor
