Anyone do GIAC software with GMG center exhaust section?
I have the GMG center exhaust unit on my GT3, and it is great. I have the exhaust bypass valve unplugged all the time. I seem to be losing some power between 2k and 4k, when compared to the valve plugged in and in Sport Mode. Since I am still in the process of breaking the car in, this is the range that I am working with right now.
Anyone have the GIAC software upgrage with the GMG? Did the software improve power in the above RPM range? Also, is there a significant difference above 4k? Just wanted some feedback before I talk to GMG.
Thank you in advance.
I have done it but since only had 500 miles on my car I am not sure about the gains. I'm not ready to go WOT yet but soon. If you want to check it out i'm in orange county.
How long have you had the exhaust? I was told that the ecu needs some time to calibrate to eliminate the flat spot. This was with the valve plugged in though. I expect the power and torque curves of the GIAC with GMG exhaust to be similar to the GIAC with Sharkwerks exhaust. Design looks very similar.
I think the GMG full exhaust is to be released in the next month or so.
When you switch to sport mode, it is not simply leaving the bypass valve open all the time and at any RPM, which is what you are doing by unplugging it. I believe it opens it up at the higher RPM's, but also at idle and some of the lower RPM's. And we know that with the full stock exhaust, our GT3's are supposed to make more midrange power when switched to the sport mode.
I think this is achieved by using that valve to control the correct back pressure at certain RPM's to make the best power with that exhaust. So if you just unplug it, you get the louder exhaust at all times, but you may not be getting the best power, especially in the midrange.
If I understood James correctly on this, then it would explain why you are noticing this drop in power with the bypass valve unplugged.
the GIAC software tuning was done at EVOMs facility with our exhaust section but I would imagien it being absolutely fine
Platinum Dealership
yes that is the system...I'm lucky that our track locally has no sound police, only fire trucks.
It's pretty pricey but getting an entire exhaust system seemed like something I can afford to risk $-wise and I'm sure everyone will want to hear the results both literally and figuratively. I wanted the meanest/ loudest solution, and this is it.
I'm not sure how much that "the powers that be" want me to disclose on the nature of the product but basically GMG has the connection in terms of this mod. It was being hand-built last week, and getting shipped to my car. I heard from my mechanic, and I will be running a before and after dyno for everyone's benefit. I will post pics and info ASAP.
