Some track footage followin a Superleggerra.
G.
http://us.sanyo.com/entertainment/ca...productID=1457
About the size of a packet of cigarettes.
The sway bar is a straight swap, plus some bushes i think.
It's set in middle setting now, which is 20% stiffer than the original one was when on full stiff.
Car is still very stable, but you now have a fine balance between over/understeer, rather than just having to drive around the chronic understeer before.
It's great now.
No problems, you will love the new set up.....
But mate, if you want any advice at all from me, DO NOT fit a 265 front tyre.
the thing with this new set up, it makes the rear end a lot more active, and this in turn gets the rear tyres quite hot (especially these N0 ones that don't handle the heat aswell as the old style ones)..so the car can be a little edgy when the front are just getting to temp, the rears are starting to get very hot, if you put that 265 up front, you will have monsterous turn in, and just make this issue worse, and i think you will totally overwhelm the rear end.
I really advise to start with a 235 1st, as the car is so different.
These 2 different style of Cups have very different heat capacity from what i have found.
We are running zero front toe now too.
G.
G.
I'm also at zero toe to actually the very slightest toe out
thanks again
paul
So sick man, I love the feeling of carrying out more speed than the guy in front of you, easing into it, easing into it then all on it and reeling him in mmm ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Thanks for sharing!
Thanks for sharing!
Great driving, and great video! Thanks for sharing! You were much more the gentleman than I would have been in that situation with the Lambo. You might have been evenly matched with him in previous sessions, but in that session you were clearly faster. I tend to get "hard on the headlights" when people do not let me by...
I gave up golf for this track addiction... Proper etiquette is important!
-Blake
-Blake
Sway bar is around £250
Here's another vid of me following another mate around there, he has the sway ber done too, he is usually right on the pace, but this day was not at his best.
http://s87.photobucket.com/albums/k1...urrent=SS3.flv
nice video.... talk about being held up .... the lambo and cup should have given you several point bys...
if this were de event here this thread would run on for 60 pages about not bieng pointed by!!!!!!!
nice drive you got alot out of that rs
siverstone seems like an awesome track to actually get to drive on, the best i can do is keep playing it on F1 with PS3. which really helped me identify every turn after watching your videos.
very nice driving as well!!
You'll see me coming past this 996 RS 50 seconds in...
http://www.youtube.com/watch?v=p6E7o17MAkI
