replaced my aerokit "lip"
I purchased a replacement (black mat finish) lip in the Fall from Sunset Imports ($114.95 + $22 shipping) - got around to the installation this afternoon.
All of the DIYs on this subject are accurate: putting the new one on is a snap (no pun intended), but getting the old one off is a motherf**ker. Because of the design of the tabs, you are pulling against a ridged edge - kind of like pulling an arrow out (ouch) as opposed to pushing all the way through the body. I ended up ripping my old lip in several places based on the amount of energy that I had to use, but no damage to the remaining parts of the spoiler assembly. I'm sure if I did this for a living, I would figure out the exact angle from which to pull to keep the lip intact.
Now I just wait until the snow clears to scrape up the new one.
Basic Sponsor
I put a new one on when I did the concours and then put my old one back on. I just worked with it slowly and at different angles and it came right off both times.
![](https://rennlist.com/forums/signaturepics/sigpic53041_8.gif)
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
Are you guys talking about the front lip below the splitter? I ordered a new one and they said that the tiny little piece that bolts on to the plastic splitter in the middle section was over $300!!! Is this right? It sounds crazy...even for a PCar.
Basic Sponsor
Mine was around 150 if I recall correctly. You should be able to get both pieces in the range of $350. I'd do some checking around.
Sunset Imports, Beaverton, OR (503-641-8600)
part #997-505-983-92
Hope that helps. BTW, I was outraged at $115 because they were only $80 in early 2007.
you should look into getting the cup car motorsport part ...
Also on the matter of the fasteners ... I believe that you can pull out the press-in "stud" that secures them with little or no problem and the the expanding "plug" comes out much easier ... this was certainly
the case with the 996 spoiler lip
This may sound cheap though but I've been using double layering of Gorilla tape over and around the bottom edge of the lip and so far it's been working out very nicely in minimizing scuffs and scratches. The black color of the tape matches the lip very closely. It's so that one stands 2 to 3 feet from the front bumper can hardly tell the existence of the tape. Black electrical vinyl tape gives the most perfect match in color and texture, but it's too narrow (only 3/4 in.). So every now and then I'd just replace the tapes if it started to look bad and the lip still remain in good condition.
I'm sure that you guys know this trick, but just in case someone has missed it:
I put my PASM in sport mode when I'm creeping over a particulary sharp curb/dip. The firmed suspension seems to give me another inch or so of practical clearance by reducing the "jouncing" effect.
