Replacement Rotors
Contact is steve@jzmachtech.com http://www.jzmachtech.com
GT3 player par excellence
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I recently finished two sets of 993 TT front [rotor] hats in aluminum. The weight delta is just shy of 2lbs per corner. Certainly substantial as this is both unsprung and driven weight!
Is this a complete assembly or do you take existing rotors and retro in the hats?
If it's the former, it's a great idea. Can you PM me with pricing?
Thanks,
David
Has anyone tried out the Performance Friction rotors from Synergy Racing for the 997S/GT3?
Basic Sponsor
Since we are on the brake subject...are you guys changing out your brake lines or keeping OEM?
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
Can anyone recommend replace steel for the PCCB's that will fit the PCCB calipers?
I have been using the Protosports and they are really GREAT! but I'm looking to find some weight savings so I'm going to something lighter.
...and getting ready to put these on, just have not had the time with other projects like the roll cage. You can get them from CDOC.
Get the GT3 cup rotors. They are actually less expensive and lighter. They are thinner so they won't wear as long, but that doesn't matter because they will eventually crack as drilled rotors will
