Tire Pressures for Pirelli Corsa Tires ?
There’s lot’s of threads for other tire makers on this topic, but I haven’t found any for the Corsa’s.
So, what kind of tire pressures are you guys running with the Pirelli PZero Corsa tires ?
I’m referring to “hot” tire pressures, as you would use on the track.
34 PSI hot at the track seems to work pretty well. There's a thread on here somewhere from Hank Cohn who is a really good pro/am racer and knows his cars and knows Road Atlanta like the back of his hand, and he ran his GT3 with Corsas at 34 PSI hot. I've tried it and it truly does seem to be a good compromise pressure for the track. Try using the search function and type in Hank Cohn and you'll find several threads on his experiences with his GT3 at RA.
Cheers!
Cheers!
I did a search and read as many posts by Hank as I could find.
You are correct. In one of the posts, he suggests 34 psi hot for both the front and rear. I've been running 33/37 hot, and it seems to be OK, but I'd like to get more opinions.
