fyi, sharkwerks rear exhaust replacement pipes weigh 5#s
#32
Hey NSXTC, it's interesting you found that out. Another customer told me the same thing that when using our bypass system and unplugging the byapss there was no resonance where as with the stocker that you did actually get resonance. Strange and I'll need to try that... If so that'd be a cool and unintentional benefit
#33
Hey Alex,
Yep, no drone whatsoever with your exhaust w/ valve unplugged. You'll definitely get a much better sound < 4000. It's sweet. With the valved plugged, it sounds almost normal. You gotta try it man! It should be mandatory for everyone with your bypass.
#34
#36
#38
hey tom, honestly we've tried different cat solutions and for anyone that goes to the track... it's _very_ likely they'll come apart on you. Very I'd say keep 'em stock. It would need retuning for that since the back-pressure changes quite dramatically as well.
Hey guys, this third batch is going out on Monday/Tuesday and I'll pm you guys the tracking etc... Thanks again!
