Is PSE off if sports mode is off?
What's PSE?
***Edit*** I take it you mean "Porsche Sports Exhaust" aka Sport button? If it's in Normal mode, it'll opens the flaps after 4K RPM anyways, but you don't get the benefit of revised throttle mapping and revised TC settings as you would with the Sport button on.
One way of finding out is to simply unplug the flapper control valve and you can definitely tell from the difference in exhaust note.
Are you saying that when I start the car, the sports button is untouched and off, in this situation that the Porsche Sports Exhaust flaps are such that the sound is amplified after 4k rpm?
My initial thought was that when you start the car, it was in quiet mode (the switch un-touched) meaning there is never a change in flaps resulting is a different exhaust note. Then when you depress the Sports switch the engine map advances and the flaps in the exhaust change back-pressure and become louder at 0-5mph and then after 3k RPM's.
Sorry, I came from the days when PSE was easier to figure out. I am beginning to think the GT3's exhaust not comparable to a 997 PSE?
When this button is pressed... torque is raised by up to 25 Nm between 3000 and 4200 rpm... achieved by an additional reduction in exhaust backpressure...
Yes, I agree with all of the above, but what is allowed to happen to the muffler flaps if sport button is off? Do they continue to respond to RPM? It seems like it driving the car.
They open at higher rpm.. ~4K (if I remember correctly) and up. In sport mode, ~3K and up (with med/heavy throttle). They won't open below 4K in normal mode regardless of throttle position. And, they stay shut at idle.
Still plays with cars.
On my car when you start the car, the flaps are open. Increase speed above idle and they close. With the Spoprt Button pressed the flaps open around 3500. With Sport "off" it is around 4000 when they open. I pulled the plug in the engine compartment and now my flaps are open all the time.
On my car when you start the car, the flaps are open. Increase speed above idle and they close. With the Sport Button pressed the flaps open around 3500. With Sport "off" it is around 4000 when they open. I pulled the plug in the engine compartment and now my flaps are open all the time.
Thanx
