LWFW
#46
I personally still think it is a reasonable mod considering it is fully OEM and without warranty issues.
At this rate I expect that my car will be in the shop within days. While its there I might as well ask them for a track alignment, any specific tips for that or just go to spec?
And anything else at all to do while the car is there? 1k miles, change the oil? Upgrade the brake fluid?
At this stage I am just planning a few DE events with this car, depending on my comfort level with it after that it may or may not become my track car - in which case it would get a full cage.
Thanks in advance.
#47
Just to avoid confusion: my friend "DanP" gave me his account years ago but this tends to cause confusion when I meet members so I registered today under my own name.
Thanks,
Ralph
Thanks,
Ralph
#48
If I remember correctly, I paid about $1,200 for parts from Sunset. Dealer was doing the RMS at the same time but said the 996 tranny could be removed with the motor in place but the GT3 has different tranny and he usually took the engine/tranny out in one piece due to reassembly alignment issues. Oil cooler gets in the way? I'm guessing it can be done either way, it's a matter of taking the time up front or fighting with possible alignment issues doing it piecemeal.
Bottom line........great mod. Can only hear the noise when the windows are down, sitting in traffic. Would definately do it again.
#51
#53
porsche says engine has to be dropped. There is a bracket on top of the transmission for what i understand is to prevent the engine and transmission from moving into the passenger compartment in the event of an accident. much like the steel cable on non gt3's. This bracket creates large clearance issues. Also when installing the lightweight flywheel a longer "clutch fork" which is what actually pulls on the release bearing must be installed. when doing this it is much more difficult to keep the fork in line when installing the crossshaft for the clutch fork itself. there is also a large possibility of broken parts when attempting to remove the transmission by itself due to stresses put on parts in ways not figured into the design. Non gt3' transmission can be removed by itself no problem. But when dealing with very expensive and cherished cars there is no reason to attempt to cut corners as far as im concerned.
#54
That is the same information that I got from the dealer doing the install and after the fact from the dealers that came in at lower prices initially. Better to do it right the first time.
#55
since i'm not a motorhead, i cannot comment on the above but since i have had the lwfw installed on my gt3 by a porsche tuning shop called Gtek in toronto (owner's name is jack - ph# is 416.755.7884) - i can tell you they had no problem putting in the lwfw just by removing the tranny (no engine pull)
- so,if you want to call someone who has actually done it and has been working on and racing porsche's for most of his life give him a call
#56
We change out the clutch discs on Cup cars almost weekly and only drop the Trans, takes about 5 hrs if you are loafing. On occasion a street 996 for a LWF and it tool about 4 maybe 5 with a trans jack.
regards
regards
#57
#59
It's in. It sounds great. On the street it's much more responsive. It chatters a little with the clutch out in neutral, but you can only hear it inside the car, so you can enjoy it and not disturb your neighbors (as if that was the primary consideration). Up and down on the revs it is dramatically faster. Final test will be on the track. For those of us who do not need to delete the A/C, Sun Roof, Nav, Chrono, Sound System, and every other thing associated with creature comfort, this and maybe lighter wheels look like good starting mods. That and learning to drive better, smoother, faster. There are no trophies at DE events. It's all about having fun and being safe. Just one man's opinion.
#60
What I love most about the LWFW is how instantly the engine blips on downchanges. It's like blipping a motorcycle. Enjoy!
