295 on 12 inch wheel?
10-07-2007, 11:11 AM
Can you put a 295 tire onto the GT3 12 inch wheel or is 295 too small?
10-07-2007, 11:19 AM
Quote:
Originally Posted by
seattle_sun
I think tire experts would say no. The rim width range for PS2's in this size is 10-11 inches
10-07-2007, 11:27 AM
which brand are you thinking, differant brands are ok
Reason: grammer
10-07-2007, 11:32 AM
10-07-2007, 03:05 PM
for the winter season i put 295 snows on and it looks rediculous - way to narrow a tire but i only plan on using them to drivie a couple times a month to keep the car in working order - there is at least 1cm of rim on each side of the tire
10-08-2007, 12:22 AM
305 or 325's. Anything smaller looks small. It would work mind you.
10-08-2007, 04:19 AM
295 on 12 will overstretch the tire too much and it's worse when u put on soft sidewall tires like PS2
so 305min IMO.
10-08-2007, 10:47 AM
Newbies Hospitality DirectorLifetime Rennlist Member
seattle_sun
295 is way too small for a 12" wide wheel. Here are the 19" PS2 specs from Tire Rack.
Tire ............ Rim Width Range ... Measured Width
295 ............... 10.0 - 11.0" .............. 10.5"
305 ............... 10.5 - 11.5" .............. 11.0"
315 ............... 11.0 - 12.0" .............. 11.5"
345 ............... 11.5 - 12.5" .............. 12.0"
Tire Rack PS2 Specs
10-08-2007, 11:41 AM
305 is actually still a tad smaller for 12J..
I think best for 12J is 325 but hard to come by
10-09-2007, 11:32 AM
Sorry I don't have it now, but once I get them I'll post a couple pictures of a 305 on a 12" rim under full cornering load. It's interesting to see the wheel pushing out past the tire.
10-12-2007, 02:21 AM
Got it now. 305 on a 12" rim at full-tilt boogie.
10-12-2007, 09:34 PM
Dr Car,
I am curious to know what brand tires you have on the pictures. MPSC are usually larger than a Toyo for example.
10-13-2007, 02:33 AM
A Conti will work, but not a Bridgestone.
10-13-2007, 09:15 PM
stisseront
Dr Car,
Those are 305/30/18 Kumho Ecsta V700 on an 18x12; front is a 245/35 on an 18x9. This is a cheap R-compound tire and I enjoyed it a lot.
10-13-2007, 10:19 PM
Has anyone tried the V710?
