Adjust sway bars to reduce understeer and roll?
**Edit** It seems like the swaybar is maxed out stiffness for the rear, so can't change understeer as I would have liked by just adjusting swaybars.
Has anyone given this a shot? I would like also to reduce body roll at the same time.
1) To reduce body roll, would it be enough to move both f/r mounts one position inward?
2) To decrease understeer, make the front softer than the rear
So the net is to move the rear swaybar in by 2 positions and the front in by 1.
Would this work? Why/why not?
To reduce understeer (when adjusting sway bars only), you need to soften the front or stiffen the rear. To soften move the link to a hole which is closer to the free end of the sway bar. If you move both one position "inwards" , you will be stiffening both, which may not correct your oversteer issue.
When changing mine around, I went center/center for a session, then adjusted them from there in proceeding sessions to correct for over/understeer until I got them to where I wanted.
Still plays with cars.
Stiffer bars equals less roll. To stiffen move the bar upward. In other words fewer holes between the mount and the bar equals stiffer.
Under steer is mitigated by the difference between the settings of the bars. Minimum understeer is with front full soft and the rear full stiff
Note on roll, some roll is not a bad thing. Roll adds grip to the outside tires. In the wet,roll stifness will reduce grip.
I've been very successful with one hole from full stiff in front and full soft in the rear. Try it, you'll like it. Lots of hook up in the rear, much less understeer in the front.
I ran my bars similiar to sasportas for a while while running Toyos R888s. I then ran a set of Hoosiers, and the car had a lot of push, so I adjusted the front bar from full stiff to full soft and they worked great. Going back to the Toyos I adjusted again (but found I liked a stiffer setting than the original full soft)
Well, I feel a little push on the MPSCs on the street. I'm gonna increase tire pressure in the rears a couple of lbs first to see how that goes then make incremental adjustments afterwards. Maybe soften the fronts up too.
Yes I agree. Adjusting the roll bars does depend on tires and camber. I'm running the MPSC with -2.4 camber front. I think that the spring rates that come stock also factor into the equation as well as if you run the car with the sport PASM setting. Lots of variables to say the least. For some reason though, the car likes a softer rear bar. Puts down traction great. Of course this will lead to some push.
Whoa there! Are you adjusting your handling for street or for the track? Steet driving is a way different ballgame, simply because its very, very difficult to get your tires up to operating temperature, especially MPSC's. FWIW
LOL...Well, it's agressive street driving. Went out to the mountains with a dozen of P cars today. Had 28F and 34R and feels better. The MPSCs were somewhat to temp. Saw a 5 psi increase when we were midway through our spirited drive. Taking the car to El Toro (abandon airport) in a couple weeks. Will have a better sense of handling then. I'll bring the tool kit and make incremental changes.
In my hands this car understears like a pig. I have been preety happy with full stiff rear and full soft front. Any other setting had way too much understearing.
Try it and let me know what you think.
Stephan
Stephan
18" wheels with MPSC's 235/40-18 and 315/30-18 help but it still comes down to driving style and "you can put lipstick on a pig, but it's still a pig"
I notice with your setup, the fronts are 40 profile which will have more sidewall flex (vs. the 35 profile on stock). I could see how this could reduce understeer, but the larger rear would negate this. As a result, you would be where you started.
