Safe Jack Stand location for an RS
Need some help. Where would be a safe location to put a jack stand underneath an RS?
I can fit my jack at the jack point and lift it safely but not sure where to put the stands.
Any visuals would be great!
Thanks in advance.
Thanks in advance.
Here's some pics from mooty...
https://rennlist.com/forums/997-gt2-gt3-forum/381462-after-495-track-miles.html
The way I did it was put lift under the rear, then jacked it up until you can fit a stand under the front.
Repeat on the other side for the other front.
Now you have the front on stands.
I heard you're not supposed to, but I think (I hope) it doesn't apply for dry sump, but I put a jack under the split case and jacked up the rear.
Then I quickly slid the stands under the rear points.
BTW, used hockey pucks all around.
If someone has a better method, please share. I really don't like using the case as the lift point.
GT3 player par excellence
most of the cup car guys jack right on the split case (when not using air jacks), i think all the 964 and 993 guys do the same, no?
There are some jack pads on this page. One for a ****, I mean slot!
http://www.pelicanparts.com/catalog/...MISCLL_pg4.htm
Wow, $73 bucks for one jack pad? 4 hockey pucks cost me $4.00. I guess you get what you pay for when it's for a ****, I mean slot.
two, what you really want is jack a hocky puck. they work really really well.
three, instead of thinking of what pads to use, buy the RIGHT floor jack. i ahve seen some cheap jacks ppl use that i would not trust to use on any cars i own. some dont have to right jack plate and lead to cars slipping off.
four, get the right jack stands. AC hydraulic make the BEST stands for our cars. if your car slips off these stands, God help you.
Allegreto, I bought that lift and secure jack from sears. It's great. The only problem is of course the RS is too low to fit it under the car. I had to first jack up the front right wheel to get enough clearance to put the lift and secure jack under the right rear.
Anyone find a trick to get the car up a few more inches to use something like the lift and secure jack?
?? My aluminum Craftsman Race jack fits under my RS no problem. It is very close but it still gets under there. I jack from the rear and put one stand under the front point and the other under one of the heavy aluminun structural parts in the rear. Go to the other side and repeat. I need to go back and forth a few times to get it high enough for a creeper.
Edit, my jack has a rubber thingy inside the cup. The cup fits around the jack point and the only thing that hits is the rubber thingy. I use a small mirror to locate the jack cup. No chance of the car slipping off the jack with the cup around the jack point.
