How well does your rear end grab?
Out of pure curiosity, say you had Michelin 'X' tires and 4-18" rims and 4-19" rims. Wouldn't the 19" rims& tires work better because of a bigger contact patch?
I'm wondering that as well as it seems logical that the 19" have larger contact patch. I understand a lot of 997 GT3 owners are going to 18" for track use for less weight. Is the larger sidewall (softer) on the 18" contribute to better grip in the rear?
Originally Posted by GlennMc
Silly question, but you did you go on track with any of this tyre sidewall black stuff ??G.
On flat surfaces i find it tough to loose grip at the back without judicous right pedal, but at cold 36psi+ rear it skips on bumps in an excitring way.
This is starting to concern me, I have an 08 RS on order great car to look at but what good is it if you can't track it with confidence. They are supposed to be track focused production cars?
See my other post video spins @ Limerock many owners are spinning/crashing there brand new cars?
I hope there is a fix for this.
Originally Posted by Ray G
Good point, but no, my tires are naked.
GT3 player par excellence
911 is intrinsically challenging to drive, that's part of the fun.
test it out, change alignmentment, play with tires....
Maybe 18 inchers are in my future.
That's a great color 993, Ocean Blue?
Originally Posted by NoSubEDU
What's amazing to me is how the EVO mag videos and some of the other tests resulted in such high ratings for the car. I am assuming they were using OEM tire/wheel combos. I have yet to take mine to the track so I will withhold my "official" comment until I do so.
Haven't read carefully through the replies. However, my first track day with my car and I was disappointed as the rear was a twitchy *****. Very daunting. But puckering in 90 mph corners.
Until I really pushed the car hard and after some hot lapping stressing the tires and managing pressures did the grip 'come in.' From that point on, it felt exactly like I expected. Sub-hoosier grip but with perma-grin g-force ear to ear grins.
My theory: street miles harden up these MPSCs and they need to be scrubbed in pretty hard on track before they come in. But they will, but it takes a good bit of abrasion and heat. These tires are not fast out of the box after notable street miles.
Originally Posted by frayed
, my first rear was a twitchy *****. Very daunting. But puckering in corners.
Until I really pushed hard and after some hot lapping and pressure did the grip 'come in.' From that point on, it felt exactly like I expected. grip but with perma force.
My theory: harden up and scrub pretty hard before they come. But they will, it takes a good bit of abrasion and heat. These are not fast out of the box.
Dude....what's your point and how do you come in here cracking like that?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
My alignment was checked, and it was good. It's now set to the recommended track setting from the manual. I am also having a new set of tires mounted. I will be going to the track July 4th to test out the setup. I have a theory that it is the tires. For whatever reason, the more laps, the slippery they got (even when adjusting pressure down). If it were a suspension problem, it would not change from lap to lap. The tires behaved just like heat-cycled out rubber. Maybe I got an old set, or driving on the street altered them. I don't know, but I'll check back after July 4th.
Hmm. That's interesting... and disappointing. I plan to set mine to the recommended track settings in the manual so we have a known starting point.
I think you are the first person other than myself to say they had rear traction issues.
i learned that my tire pressure was too high and that my sway bars were off.
i dropped pressed to 28/30 at the start of a session and let it build to 34/36 and it was much better - i also softened the fronts and stiffened the rear.
i have had better luck since then but it still wants to step out more than i would expect under throttle exiting a corner.
Greg
Originally Posted by crispenigl
interesting observation - i have noticed that my tires do get better with wear during the end of the track days as well
