seats
GT3 player par excellence
seats
i installed some seats in the RS and had thorax air bag, seat belt buckle and AWS turned off. however, i still get the little airbag light on the dash, no chimes, just the glowing red light.
those of you installed aftermkt seats, did you turn AWS, buckles and thorax bag off ? and if so, do you get the red bag warning light?
Originally Posted by Carrera GT
Sounds like somebody didn't have the key out while the seats were unplugged. : )
I've had 996 GT3 and Pole Positions in the 997.
Maybe the tech with the PIWIS neglected to follow every menu.
i was there when they did the PIWIS thing.
POSIP
CODING
DRIVER BUCKLE OFF
PASS BUCKLE OFF
DRIVER THORAX BAG OFF
PASS THORAX BAG OFF
AWS OFF
we did the same on my cayman s. all lights are off
another person did same on cayman s. the airbag light stays on.
my RS air bag light stays on.
do you know the exact sequence of PIWIS operations?
did christian turn off yours?
Originally Posted by mooty
the key was in my pocket when the seats were unplugged.
POSIP
CODING
DRIVER BUCKLE OFF
PASS BUCKLE OFF
PASS THORAX BAG OFF
AWS OFF
POSIP
CODING
DRIVER BUCKLE OFF
PASS BUCKLE OFF
PASS THORAX BAG OFF
AWS OFF
I'm sure Carlsen will clear it up for you -- or did you take to somewhere closer to you?
I had a little brain fade and opened the sunroof while I had both seats out. Damn you sunroof!
I don't know of any sequence dependencies. I just watched a tech enable an RS during the PDI and it was obviously very easy to skip an item just because the menus are tedious and the PIWIS is insanely slow.
i will visit carlsen to see if christian can figure it out.
