997 GT3RS Rollbar in a 997 GT3
Looks like someone got it to fit with custom mounts ... to bad my 997 tequipment bar shows up tomorrow ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
http://www.6speedonline.com/forums/s...ad.php?t=80007
That's pretty clearly a first effort. Surely they'll tweak it, get their logo into the CNC model and presumably figure out a way to use a less extravagant billet (since it's about 30% waste just at a glance.
why didn't this fit before? was the oem plate mounted inside the car effectively raising the bar and not clearing the sunroof? I see the plate is shaved to reduce weight but still have the big foot print. Also appears to have SS threaded sleaves? that is a nice touch. Is the RS bar easier to install and remove or something? Still not sure why it would be more popular option that the custom ones designed here.
GT3 player par excellence
Originally Posted by carrering
...Is the RS bar easier to install and remove or something? Still not sure why it would be more popular option that the custom ones designed here.
i dislike all the bolts showing on the bar. but that's just me.
Originally Posted by XSpeedFreakX
Someone please correct me if I'm wrong, but aren't the plates supposed to be on the inside?
I can confirm, the RS cage fits the GT3 with a sunroof perfectly. I had it installed 2 weeks ago. I had a plate welded to the floor INSIDE the car, however, and the front legs of the cage bolted to it. I didn't want bolts to go through the floor of the car as it is a point of rust in the future. The carpet was then reinstalled, looks beautiful.
I'll post a complete review later with photos...
Drill a hole or weld, you still create bare metal that will rust on the outside the car. Eveything needs a splash of paint. Keep in mind the weld, if any good, has to penetrate both pieces of metal (that means going all the way through whatever piece of the car.)
